Back Yard Seat Rails not fitting.
Old Mar 29, 2007 | 03:32 PM
onetyme_sam's Avatar
Default Back Yard Seat Rails not fitting.
I bought a set of back yard seat rails from bulletproof automotive. called bulletproof and told me to post a topic. anyways. the seat rails do not fit. the bottom of the seat contains a hump for the cushion. when sat down, the seat will teater on the hump not allowing the alignment of the holes to square off. also the there is a gap between the top and bottom of the seat. i need to know if this is normal.
images are at this site. please help.
http://www.imagestation.com/album/pictures...l?id=2112043328
Old Mar 29, 2007 | 10:59 PM
Ape_X's Avatar
Hey onetyme_sam,
I have this rail installed on my 06. Check my sig for the install writeup.
At first thought, I'd say put the seat in the forward most position first before trying to line up the bolt holes. The rails have a slight "rake" to them, meaning that when you slide the seat forward, it is a little higher than when its slid all the way back. once the rear bolts are in, slide it back and install the front bolts.
Now, now not knowing if the 06 and 07 seats are different, maybe the hump is even bigger than the 06.. in that case you might be out of luck, because when I slide my seat all the way back, the seat pan makes contact with the floor, but not enough to limit seat travel.
Let me know what you find. And check my writeup for my pics.
May the force be with you,
Dave
Old Mar 30, 2007 | 11:18 AM
I am having a hellacious time stick this seat back in. I looked at the seat rail more closely and i'm not sure if this is suppose to be like this but 1 bracket for the bolt is kicked to the side. looks like it was welded crooked. i am not sure if its suppose to be like this but i am fighting it and the bolt will not go in. it is the last picture.
Old Mar 30, 2007 | 12:56 PM
I got all but 1 bolt in. The bolt closest to the shiftknob. it seems im about 2 inches away. did you have any problems getting all 4 bolts in?
Old Mar 30, 2007 | 02:03 PM
Ape_X's Avatar
Wow.. this seems very wrong. My rails went in like stock... no problems. Did you test fit the rails to the floor before you bolted the rails up to the seat? Are you sure you got the LH side rails? JDM Passenger (USDM Driver)?
The crooked tab is normal, I have it on mine. I would try test fitting without the seat installed in the rails and see if it even lines up there, then I would cross check it with passenger side and make sure you have the correct side.
Dave
dwrights
Jun 25, 2019 11:56 PM
V-Spec1
Aug 3, 2017 09:19 AM
J-Speed Inc.
Oct 3, 2014 01:06 AM
gizzard
Dec 23, 2012 11:35 PM
PdC
Dec 23, 2004 08:10 AM
