Coilover Adjustment
Old Jun 19, 2007 | 06:13 AM
TrackStar's Avatar
Default Coilover Adjustment
I have BC RS coilovers and the bottom bracket used to raise and lower the height is stuck as well as the locking perch above it.
I tried:
- flathead screwdriver wedged in notch + hammer
- loads of anti-seize
- the included spanner wrench with a long breaker bar
- heat gun (I think aluminum expands more quickly than steel)
- strap wrench on the middle of the shock and a bar between the mounting holes on the bracket
Any other ideas?
Old Jun 19, 2007 | 01:50 PM
Brownergy's Avatar
Don't buy cheap coilovers? But honestly, normally you'd put a torch to it, but I'm afraid it might damage the oils within the shock. You could try a block of wood on the notch of the colar and hit it a couple times with a hammer.
Old Jun 19, 2007 | 02:01 PM
highwaystardoritos's Avatar
soak it with WD40 30mins later soak it again... soak it again 30 mins later, then try it...
Old Jun 20, 2007 | 05:58 AM
TrackStar's Avatar
I forgot to add that to my list, but instead of wood I used a flathead screwdriver in the notch.
User 111717
Jun 12, 2014 07:39 PM
chrispayze
Jun 26, 2011 08:30 AM
Dumas2k
Sep 5, 2010 09:08 AM
jacksonjw81
Jun 16, 2009 04:20 AM
TrackStar
Jun 19, 2007 12:24 PM
