E-manage Ultimate 101
Old Jun 15, 2007 | 06:23 PM
  #101
deathsled's Avatar
Originally Posted by mpower22,May 30 2007, 01:50 PM
Hey scott do you have any ap2 na basemaps I could use as a foundation for my tune?
Thanks
Matt
that's actually kind of a funny question. Since the EU is a piggyback you're working off the factory ecu. A zeroed out EU is pretty much your base map. Tune from there!
It's not like this is an AEM EMS and you need a base map to get the car started up.
Old Jun 16, 2007 | 04:04 AM
  #102
mpower22's Avatar
sorry I'm an r-tard..I'm used to my cobb accessport reflash for my sti....not a piggyback type system.....but the car get tuned today lets see what she does....
Matt
Old Dec 30, 2007 | 04:28 AM
  #103
gzob's Avatar
Has anyone tuned a boosted S2k with large injectors? How do you get away the closed-loop issue? (the ECU leaning out the AF to stoich under low throttle openings but still in boost)
Old Dec 30, 2007 | 02:02 PM
  #104
MugenRioS2k's Avatar
it requires some different wiring on the harness to allow you to trick the stock ECU into open loop sooner.
Not that hard to figure out however don
Old Dec 30, 2007 | 04:05 PM
  #105
gilbertg's Avatar
[QUOTE=MugenRioS2k,Dec 30 2007, 06:02 PM] it requires some different wiring on the harness to allow you to trick the stock ECU into open loop sooner.
Old Dec 30, 2007 | 06:11 PM
  #106
Originally Posted by gilbertg,Dec 30 2007, 07:05 PM
Actually, no special stuff required and no real secret either. You need to enable both fuel and both ignition maps. One uses TPS as input and the other using MAP.
Did not know if you wanted that cat out of the bag
Old Dec 30, 2007 | 06:20 PM
  #107
gzob's Avatar
I think there is an external adaptor sold by Greddy to alter the AF signal going to the ECU. WHen enabled (auxiliary map), it sends a stoich signal to the ECU (0.5v) so you can play with whatever AF ratios you want through the ULT.
Old Apr 11, 2008 | 07:27 PM
  #108
one_slows2k's Avatar
Excellent Post guys, I'm leaning towards getting the ultimate really soon, but could some confirm the request above?
Old Apr 12, 2008 | 05:35 AM
  #109
ScottyBallistic's Avatar
We have done over 100 installs and have never used this feature . Your car will stay at Stoich when in closed loop via the factory computer , hense why you need to read the factory fuel trims when tuning so you dont upset this balance . Then we tune the rest with a wide band on the dyno in open loop .. no need for O2 feed back .
At least we have found no need for it
Old Apr 14, 2008 | 01:28 PM
  #110
Have you guys tuned boosted applications? How was the partial throttle tuning done on that one? or did you leave the stock ecu to handle that? thanks
