E-manage Ultimate 101
Old Nov 29, 2006 | 10:57 AM
  #31
ScottyBallistic's Avatar
Let me discuss this with Giles as he is only usually available on the weekend for Saturday only and work out the logistics .
Old Nov 29, 2006 | 02:21 PM
  #32
Emil St-Hilaire's Avatar
Active Streak: 30 Days
The week-end could also start on Friday.!!!
Old Dec 1, 2006 | 11:00 PM
  #33
ATUN custom fabrication's Avatar
i have little question
i m tune cars with aem ems, that my first time i gona run s2000 with the EU,
i should put any map in, or when the maps on 0.0 that mean it will work
the same like the factory ecu?
thanking you in advance
Old Dec 2, 2006 | 05:12 AM
  #34
MugenRioS2k's Avatar
Originally Posted by Twiztid,Nov 27 2006, 06:42 AM
Harnesses no longer need to be modified
V2.0 has been tested and proven and is a must on MY06
yes I stock units and harnesses .
I have not tried the VSS option as no one has needed it . But if you do splice it in as per Modifry's yellow box instructions .
So the 2.0 Build fixed the erroneously low WCT dash display and the erroneously low ULT data log sensor readings???????????
Old Dec 2, 2006 | 05:55 AM
  #35
NeverMind
Old Dec 2, 2006 | 06:00 AM
  #36
You are welcome to PM me as I dont want to turn this thread into a teaching thread to keep confusion down as everyones car has different needs .
Old Dec 2, 2006 | 01:42 PM
  #37
[QUOTE=Twiztid,Dec 2 2006, 08:55 AM] Thanks for confirming :thumbup :
So that mean everyone we can start ordering harnesses with Water temp and use the compensation tables
Old Dec 2, 2006 | 02:58 PM
  #38
Originally Posted by MugenRioS2k,Dec 2 2006, 05:42 PM
I WAS NOT CONFIRMING
I was asking if the new 2.0 build fixed those problems.
I want to use the A/F feedback loop to get the ULT in the ball park and then fine tune the injector maps.
After all that the A/F loop would still be used to keep A/F in check when (environmental) conditions change.
I read the sentence and ignored the punctuation , Sorry . Add the word "did" as in "did it " no need to yell
I dont know why you want to waste your time with that .
Satisfy the fuel trims first -20 min drive on a NA car - longer as you have to scale the injectors on a boosted car ( using a OBD scan tool - PC based ,PDA or stand alone ) This will also allow you to read the timing .
Once thats done , 2 hrs on the dyno and your done .
Now you can enjoy the car , instead of worrying about features that are not needed .
I have used the Ultimate in - S2000, G35 , 350z , Lotus Exige , Maxima , ITR -- next projects to get it are my Miata when it goes turbo , 240sx with a sr20det swap and another with a rb26dett swap . Only the Lotus required us to develop a closed loop controller and cam controller as the Lotus ECU is far more advanced .
Never once have we needed the O2 feedback . We do use Water temp compensation on some if they have a start up problem due to overly large injectors . The factory ECu will do most of the compensation for you .
Old Dec 2, 2006 | 05:44 PM
  #39
I will be doing some crazy testing with a modified AFSC late next year and I am trying to develop some safety controls to prevent the car from running lean.
sorry about the caps
Old Dec 2, 2006 | 08:46 PM
  #40
zbrewha863's Avatar
What is an AFSC? do you mean a V-AFC?
Also, I have to agree with Twiztid on that last point -- one of the great benefits about the Greddy EU is that it's a piggyback, so the Honda ECU will still make changes for many real-world occurances (i.e. weather changes) that would take hours to tune for on a dyno.
