emanage + wideband
Old Oct 16, 2008 | 10:47 PM
METZ_S2K's Avatar
Default emanage + wideband
hey is there a way to hook up my wideband o2 sensor
to an emanage blue? it would really help to see my air/fuel
readings in my logs. and it would be alot easier to adjust the fuel
trims accordingly.
Old Oct 24, 2008 | 08:49 PM
revhi's Avatar
Yes I did it last month. Being able to data log is great. Took a lot of research on the emanage forums. I used my AEM Uego because you need the anolog oput put from it which is the white wire. You also need the wideband harness for the emanage blue that you can get from mohdparts.com. Plug the harness into the emanage connect white to white and gray from the emanage a/f harness to ground.
Set the paramater settings to a/f 0-5v and you many need to fine tune the voltage readings. You can do so by checking with your wideband. I ended up using 10 and 19 for the 0-5 voltage conversion.
Old Oct 25, 2008 | 09:21 PM
dsddcd's Avatar
The FI forum is usually the best place to look
https://www.s2ki.com/forums/index.php?showt...&#entry14398917
Old Dec 11, 2008 | 08:43 PM
METZ_S2K's Avatar
hey thanks revhi. is it possible to do this with a different wideband?
i have an plx devices m-300. it has the white and gray wires, same as
the uego. so i don't see why it wouldnt....?
sevx007
Oct 4, 2016 12:39 PM
GreeceS13
Αγοραπωλησίες
Jun 19, 2013 01:22 AM
lvd1102
Sep 24, 2009 07:14 PM
S_NeWb
Sep 16, 2007 08:26 PM
cjb80
Jul 5, 2005 06:21 PM
