Endless BBK Install
Originally Posted by Sinji,Jan 16 2008, 08:01 AM
just drove the car yesterday and I am very amazed by the clamping force of the brakes. it brakes so hard now that my tires hit my fenders when slowing down aggressively from 25mph... I might have to raise the car back up or get stiffer springs in the front to compensate...
Generally on most cars, especially well balanced car's like ours have the front brakes do 70-75% of the braking. Therefore it's not that big of a problem to have the front brakes be more powerful, they come from the factory that way anyways. It would be a much bigger problem if your rear brakes were stronger, as they would force the car to look up the rear tires and spin. If Sinji felt the car would drive a lot better if the rear brakes had added bite, he could simply just upgrade the rear pads to a better compound.
I'm not overly familiar with Endless BBK's, but in general, the main advantages BBKs offer are more consistent braking distances over substained abuse as they don't overheat as easily. It usually takes a strong master cylinder and an overall pretty stout caliper design/piston strength to give more braking/clamping force. In all actualality, BBK's often lengthen your stopping distances (a bad thing) because they are heavier, again, their advantages are that they stop at that same distance over and over again.
IMO, it's better to have OEM brakes or Spoon calipers (weight savings and better pedal feel-over OEM) with race pads, hi-temp brake fluid (Motul RBF 600 or ATE) a stronger Mstr cylinder/prop. valve and better ventilation to the brakes than a BBK. That way, you haven't gain any weight, you stop shorter, can use any pads made for the S2000 and haven't really changed brake bias.
Again, I'm not real familiar with Endless, but I do know they are a premiere brand. So is Brembo, but I'd never buy a Brembo GT kit, I'd probably buy one of Brembo's Race caliper's, like what's on Will from E-autos car. Just my $0.02.
If anyone is looking for more info, there are a lot of good white papers. I learned a lot about the physics of brakes from these.
http://www.stoptech.com/tech_info/te...e_papers.shtml
Originally Posted by mr_grand_prix,Jan 24 2008, 09:51 PM
Excellent write up...
where did you purchase the setup from?
