high capacity oil filter
Does anyone know of a high/higher than the pittifulkly small stock oil filter that is of high quality? I am currently using the Mobil1 M1-104 and would dearly like to find a bigger Mobil1 and or K&N that has the same OD and O-ring dia(or slighty larger that will properrly seal on the factory housing. An alternate solutuion woould be a sandwished adaptor that would fit up to the factory housing and then offer a bigger OD to nount a larger filter. Things we need to be careful of are inlet area, filtering media area and good quality filter media, flow etc.
Two things a high quality bigger filter will offer is increased oil volume, a minor degree in cooling and a reduced pressure drop w/o having to utilize any bypass valve function.
Does anyone have any educated solutions?
thank you in advance...
Bruce
Bruce
