Installing Cusco rear strut bar
Originally Posted by 99SH,Sep 7 2007, 09:54 PM
Would someone tell me the benefits of the Cusco SB over the OEM one? Seems like a useless mod...
anyway, the cusco bar is much stronger and makes the chassis stiffer then the oem rear bar, because the actual bar and end brackets for the cusco rear strut bar are much more beefy and connect to the chassis better, reinforcing that section noticeably more compared to the stock rear brace. The oem rear bar compared to the cusco bar is just not as heavy duty. If you had both bars together you could see what i mean, but basically the cusco rear strut brace helps reinforce that area even better then the stock rear brace.
I just put in my Tein springs and ran into the same issue.
