ITB's
Old May 31, 2008 | 05:21 PM
  #91
negcamber's Avatar
Originally Posted by Hypersonik,May 31 2008, 05:01 PM
I think you have all got distracted from the true dynamics of ITB's with a bit of CF bling
I think many are trying to find a way to filter the air going into the ITBs. So far the testing done has shown that the sock type filters fitting on the velocity stacks robs enough power to make the ITBs no better than the single throttle body.
Old May 31, 2008 | 05:28 PM
  #92
Ultra_Nexus's Avatar
The theoretical solution is simple - reduce the velocity of the intake air to as slow as possible in order to reduce turbulence from filtration.
Practically, not so easy, but then everyone knew that
Filtration must be done as far away from the butterflies as possible with as big a CSA as possible using a thin layer of foam.
I have an idea, but I think you'd run out of space.
Old Jun 1, 2008 | 09:48 AM
  #93
RedUn's Avatar
Originally Posted by Hypersonik,May 31 2008, 11:01 PM
Adding a plenum is a waste of time unless you are going for a proper ram air system.
Worse still think of the turbulence you will get from having stacks inside it!
And also think that if you ran that type of plenum, you could get away with 1 butterfly instead of 4.
You are slowly returing to the original inlet manifold design.
The idea behind that plenum is that you can run it with a Mugen/J's/ASM air intake which is sealed and I guess also slightly pressurised at speed.
BMW have been running these setups for years.
Open ITB's are better no doubt but not great for a DD.
Old Jun 1, 2008 | 10:07 AM
  #94
Mr. Francesco's Avatar
Originally Posted by ITBs2k,May 31 2008, 06:50 PM
Heres the site. Kinda long but real informative. Maybe help gives us some ideas to make one.
http://forums.hybridz.org/showthread...=127863&page=7
Interesting.
Old Jun 1, 2008 | 01:32 PM
  #95
Which is negated the benfit if the ITB's in the first place
I think you'd bu much better of designing a non ITB'ed item that flowed really well, if you are after DD.
Old Jun 2, 2008 | 04:06 AM
  #96
RedUn's Avatar
I doubt it, I guess the peak power will be about the same but the mid range with the ITB's would be much better.
I'd rather have ITB's in a plenum for a DD, bit different and hopefully more power than a normal plenum.
steven975
Jacksonville
Jul 5, 2011 05:34 AM
jzn_ap1
San Diego S2000 Owners
Sep 21, 2008 09:20 PM
killer2239
Jun 16, 2008 04:06 PM
C4SxM5
Oct 25, 2005 06:06 PM
jasimps
Apr 9, 2005 09:06 AM
