J's Racing ECU installed
Originally Posted by DannyInKorea,Mar 24 2006, 12:53 PM
Yes. I'm using J's test pipe.
When I used stock ECU, No CEL came on with J's test pipe.
And, the CEL code is different I think.
I already got an anti fouler plug (around 8cm) thing.
Thanks!!!
Thanks!!!
Originally Posted by Amuse Boy,Mar 25 2006, 10:56 AM
Seems to me that the J's is throwing a code because your air pump has been removed. Did you request that the air pump circuit be removed from the ECU?
I requested to disable the air pump to J's racing and paid extra money for cutting air pump.
Now, I removed air pump & relay.
And there is 2.5cm air horse from under intake manifold to air pump and the other 2.5cm air horse from air pump to Intake pipe.
After removed the air pump, I connected those two air horses together. So the 2.5cm air horse from under intake manifold to Intake pipe directly.
And there were 2 coupler from Relay & 1 coupler from air pump. They've been disconnected since I removed the air pump & relay.
I haven't yet touched Air control valve & solenoid valve & vacuum stuff & fuses, related to secondary air injection system.
I asked this situation J's racing and he said "replace every fusebox and relay for secoundry air injection system".
If the air pump circuit is removed from the ECU, the CEL should not be ON.
Tomorrow, I wll try to remove air control valve & sloenoid valve & vacuum horse.
Good luck.
There is a thread in Uder the Hood which talks about removing the air pump and the necessary steps to make it work correctly. I will try to find it for you.
