J's Racing straight pipe
Old Mar 17, 2006 | 07:10 AM
  #31
2QYK4U's Avatar
Originally Posted by Spec_Ops2087,Mar 17 2006, 09:04 AM
I'm running with the stock heatshield on, just in case. I do, after all, live in the little brother of california (NJ) and it is strict over here.
So you use the stock heatshield to make it look like you have the OEM CAT? You might pass a cursory inspection, but you'll fail a thorough inspection, to include smog check.
I don't think I am going to have my heatshield put back on.
Old Mar 17, 2006 | 03:24 PM
  #32
Spec_Ops2087's Avatar
I don't think a cop on the side of the road is going to do a thorough check . I highly doubt they would even do a visual check at all but I have the heatshield there just in case.
If I didn't tell you it was a testpipe, you would never know the cat was taken out...its VERY convincing
I also don't plan on running catless through the emissions inspection. I'll eithor brib the guy or just change out my testpipe for my cat temporarly
Old Mar 17, 2006 | 03:48 PM
  #33
HvRRZ's Avatar
Originally Posted by topcat7111,Mar 17 2006, 02:34 AM
That's a 63mm test pipe...I have T1r 70mm exhaust and the test pipe does not have the bracket. But i was still able to put stock cat heat shield around the t1r 70mm testpipe.
how did you mount the heatshield? Does it rattle at all since the test pipe did not come with brackets for mounting?
Old Mar 17, 2006 | 07:09 PM
  #34
rudeS2k's Avatar
for J's
Old Mar 17, 2006 | 09:08 PM
  #35
illicit's Avatar
any pics? never seen it before.
Old Mar 17, 2006 | 09:52 PM
  #36
Xplosiv's Avatar
Originally Posted by 2QYK4U,Mar 16 2006, 08:26 PM
I contemplated getting that pipe, but couldn't justify spending over $500 for something I won't be using for very long.
I know what you mean, it took me a while to convince myself for it. I only used it on the track so it was used for limited times/yr. Well, Ben hooked me w/ a killa deal and I couldn't resist. It's always a pleasure to deal with BP.
Old Mar 18, 2006 | 07:10 AM
  #37
2QYK4U's Avatar
Bulletproof is a great company. Top-notch customer service. It's too bad it takes so long to receive products from Japan; not that it is BP's fault.
Old Mar 18, 2006 | 11:39 AM
  #38
Xplosiv's Avatar
I can only wish the interval time was shorter.
hookedonboost
Nov 1, 2014 06:02 PM
etang789
Jan 23, 2011 10:01 AM
YENS2K
Socal Swap Meet
Jun 6, 2010 10:39 PM
nakedmike
Feb 7, 2010 11:28 PM
