Questions about main caps and different cranks.
Old Oct 27, 2007 | 07:46 PM
PeanutButter's Avatar
Default Questions about main caps and different cranks.
I have an F20C, but would like to put the f22c crank in it with the f20 main cap(girdle).
Am I going to run into any issures with this.
Old Oct 28, 2007 | 07:14 AM
Raven628's Avatar
No.
I put a Toda 2.2 stroker in my AP1.
Just check your main bearing codes, on the bottom of the girlde and the crank codes and you will get the correct bearing for your mains.
Of course mic them out and use plastic gauge to check everything.
Old Oct 28, 2007 | 08:29 AM
Sounds good.
Old Oct 28, 2007 | 02:39 PM
BlownAP's Avatar
Originally Posted by PeanutButter,Oct 28 2007, 08:29 AM
Sounds good.
so if you drop the F22 crank you will pretty much have a F22 right?
Old Oct 28, 2007 | 05:37 PM
Gotta change the rods and pistons also, since the stroke is different, the lengths of the rods are shorter.
Old Oct 28, 2007 | 09:46 PM
Raven628's Avatar
I forgot I loaded this picture.
Toda 2.2 crank, in a AP1 block.
Fabulous_omelet
Apr 10, 2015 05:28 AM
motowiz27
Apr 12, 2010 06:38 PM
0piston
Jan 11, 2010 06:30 AM
Spnshfirefighter
Jun 26, 2009 01:47 PM
phillys2k
Dec 9, 2005 08:42 AM
