Spoon engine damper
Old Aug 17, 2006 | 01:39 AM
ZiTrO's Avatar
Default Spoon engine damper
Does anybody have it installed in their car? Maybe you could post a pic of it installed
Old Aug 17, 2006 | 11:35 AM
AJ PwR's Avatar
The Spoon ETD requires to notch off the bracket which holds the fuse box in place and Spoon doesn't have the plate/bracket to hold it back in place If you want the fuse box to sit hangin then go for it.
Old Aug 17, 2006 | 12:31 PM
The White Mandingo's Avatar
J's ETD doesn't do this correct?
Old Aug 17, 2006 | 02:40 PM
Stealth Operator's Avatar
No ... J's come with a proper bracket and heatshield replacement as well. However, it'd require some modifications to fit onto LHD cars as this is a RHD kit.
Old Aug 17, 2006 | 04:56 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Who makes a Damper,that is simple "Plug and Play"???
Old Aug 17, 2006 | 07:42 PM
GT Motoring's Avatar
Former Sponsor
J's Racing makes a US spec specific version.
Old Aug 18, 2006 | 07:59 PM
Shadow_S2K's Avatar
Former Sponsor
But it isn't "plug and play" ...you have to take remove a welded fuse box bracket before you mount it...
Old Aug 18, 2006 | 09:52 PM
ERL_S2000's Avatar
I have the J's and you just use a hammer and a chizzil and knock off the bracket that holds the fuse box. Its very easy to do. Take 20 seconds and then you just install the bracket for the ETD if you dont already have the ETD and STB combo by j's since the Combo already has the tab on the side. Overall Its easy and isnt going to cause a problem.
Old Aug 18, 2006 | 11:55 PM
Shadow_S2K's Avatar
Former Sponsor
Not a problem until you want to possible remove the ETD? Regardless of how easy it is to remove the welded fuse box bracket...its still not a simple bolt on that some some people are led to believe...and I cannot say the end result is worth the trouble of removing that piece in the first place...looks good though don't it?
Old Aug 19, 2006 | 04:36 AM
ZiTrO's Avatar
Even with the Spoon one, I've been trying to figure out how to put it there
