Stock ecu vs JDM ECU
Old Oct 11, 2007 | 10:55 PM
ocd_2k3's Avatar
Default Stock ecu vs JDM ECU
hey you guy i just got a used motor and i was wondering if i should used the stock ecu or the JDM one that came with the motor. Can anyone tell me the differences between the both of them
Old Oct 15, 2007 | 10:08 AM
INTJ's Avatar
Guess nobody knows. I can't imagine you would have any issues except maybe smogging it. I would run it and see.
Old Oct 15, 2007 | 10:13 PM
hollywood_s2k's Avatar
You would have to use the keys and ignition from the jdm one wouldnt you?
Whats the difference in them anywho?
Old Oct 16, 2007 | 05:48 AM
revmatch's Avatar
is it an f20 or f22? i think japan eventually got the f22 later, whereas europe kept the f20 until now. i assume yours is an f20?
since the jdm motor makes a touch more hp due to a little more compression, i would think you should stick to using the jdm ecu that 'should' be tuned to that motor. the mapping on a usdm f20c ecu could be slightly tamer since our motors have a bit less compression. not suer if this is 100% tho but makes sense to me. you also may run into hvac issues, etc. too - u never know, but could always try a usdm ecu on the motor, may work fine.
Old Oct 16, 2007 | 06:20 AM
SOHCmyDOHC's Avatar
JDM ecu = no immobilizer and tuned for higher comp ratio
Anyone feel free to correct me if I'm wrong
Old Oct 18, 2007 | 08:05 AM
^^^ Sounds about right.
It may not have all of the emissions control like ours do also. But I dont know.
Old Oct 21, 2007 | 05:40 AM
i</3speedbumps.'s Avatar
for anyone who is wondering, jdm f20c do pass california smog.
Old Oct 23, 2007 | 11:30 AM
Duke of Cruel's Avatar
use the jdm ecu
DoC
Old Oct 23, 2007 | 12:10 PM
moogleii's Avatar
That won't run so well on 91 tho right?
petros ae86
Κινητήρας - Μετάδοση - Περιφερειακά
Mar 22, 2013 05:06 AM
darkknight
May 19, 2011 12:30 PM
fuentes_s2k
Aug 8, 2009 07:33 AM
i</3speedbumps.
Jan 10, 2007 09:13 PM
