Toda ITB's?
The twm throttie bodies require more custom fabrication ( cooling system). Also you may want to leave the heat off the car. I didnt reconnecy my heater core lines. In all if you are looking to take it up a step they are a good investment if you are doing track days or want to extract as much NA hp as possible. I did the 52mm ones and dont regret it one bit
We need to put together a ITB video page/thread!!!
Also waiting on the ITB from fuji to come out.
I have been talking to Fuji about making a dual injector ITB setup (8 injector total).
The four fuel injectors go in the velocity stacks for improved mixing and some cooling of the incoming air stream(increased density).
And four water/meth injectors in the normal stock location (activated with Vtech) to again decrease intake air temps (increase in density) and to increase detonation threshold.
And then later on develop an intake to feed turbo pressure to the hole system.
Imagine the flow rate increases with a turbo +ITB
