VAFC II gains
Old Jan 19, 2007 | 03:18 PM
burak's Avatar
Default VAFC II gains
I have AEM V2, Invidia V3, and berk test pipe installed on the car.First run, the car had 201.88 hp and 135.96 torque with all the mods. After, I got it tuned , it was 204.90 hp and 138.68 torque. Now, the Vtec kicks in at 5100rpm. I will scan the dyno chart soon and post it. The only big difference seems between 5k to 6k RPM. It seems like, I picked up around 10-15 hp in that range. Other than that, the diference is only a few hp throughout the all RPM range. My tuner said, he adjusted the A/F ratio as 14/1. Does these gains sound about right? I was expexting little more peak HP.
Old Jan 19, 2007 | 03:24 PM
BlownAP's Avatar
[QUOTE=burak,Jan 19 2007, 04:18 PM] I have AEM V2, Invidia V3, and berk test pipe installed on the car.First run, the car had 201.88 hp and 135.96 torque with all the mods. After, I got it tuned , it was 204.90 hp and 138.68 torque. Now, the Vtec kicks in at 5100rpm. I will scan the dyno chart soon and post it. The only big difference seems between 5k to 6k RPM. It seems like, I picked up around 10-15 hp in that range. Other than that, the diference is only a few hp throughout the all RPM range. My tuner said, he adjusted the A/F ratio as 14/1.
Old Jan 19, 2007 | 04:14 PM
Johnny Sack's Avatar
14.1:1 is lean. you might want to knock it back to 13.5 or so.
Old Jan 19, 2007 | 08:09 PM
KnowledgeIsPower's Avatar
im thinking about getting a vafc II....i have an 01 and from what ive read that MY seems to get good gains.
can i ask you guys what you paid total for the setup (unit, harness if any, tune time)
impressions? worth it? reasoning?
thanks guys
Old Jan 19, 2007 | 11:00 PM
LagunaS2K's Avatar
Originally Posted by BlownAP,Jan 19 2007, 04:24 PM
I picked up about 8 peak HP and up to 14hp after peak, my car is no where near as lean as yours and I had no mods other than the VAFC II
check out my before and after dyno. P.S. I have since changed my vtec back to stock, I really dont need it set lower, If i ever do any spirited driving or racing, youd better believe im over 7k
WOW big improvement!!! looks allot better!!!
the VFAC seems like it might be slow to react because you still have that curve where it slightly dips causing a gradual exponential curve from 6400-7000RPM thats the point where the A/F gets rich again then leans out to roughly 13.4-13.5 your final HP number is good... you can fine tune the mid range iron out the fuel trim to a rock steady 13.3-13.4 and your mid range acceleration power would be SWEET.
Old Jan 19, 2007 | 11:02 PM
LagunaS2K's Avatar
thanks guys
i would suggest Emanage Ultimate! this gives you timing adjustments, and both acel and decel compensation...
you will ultimatly get the same top end power but your mid range and acceleration can be tweaked and more refiend than the VFAC.
but the VFAC is a great start.
Old Jan 20, 2007 | 12:34 AM
AP2's Avatar
AP2
silentdancer had a VAFC II and the shop that tuned it got him +9 whp....I am hoping to have my VAFC II tuned by Church Automotive to see what my AP2 can put down...
Old Jan 21, 2007 | 05:21 AM
S2SEXY's Avatar
wheres that dyno sheet at?
Old Jan 21, 2007 | 05:10 PM
burak's Avatar
I added the dyno chart, sorry it is a blurry picture since I took it with a cell phone.
Old Jan 21, 2007 | 08:17 PM
BlownAP's Avatar
looks like you got some good gains down low and up top after 8200,
the A/F curve looks SOLID ( a tad lean) , they did a great job on making the corrections . I wonder why the gains are not higher??
