what size time attacks w/ js front fendrs?
alright i whipped open the charts
first of all
idk whether u want CE28 or TE37 time attacks but ill say both
oem fenders can fit like 9+52 easy.. so 20mm fender.. brings that to.. 9+32 ish fine fitment.. which is fine for bbk..
CE28 fitment id run...17x9+35 17x10+45
Te37 9+400 9.5+40
wider is better not only for grip.. but to push centerline in moving tire centerline in... the 17x9+35 u can run 255.. but id run 245 17x10 u can run 285 EASY
first of all
Te37 9+400 9.5+40
orderd some yoko's(ao48) in 245/40/17inch all around
and placed an order with steve for ce28n 17/9 35mm off set, for all 4 rims.
next on the list is the wide fenders, and since j's does not make the rear fender covers anymore i will have to pay close to 800 bucks for ones made by asm.
Originally Posted by rijowysock,Jul 6 2006, 12:21 PM
why do you need rear fender flares,. the j's ones dont even widen anything.. still same clearance.. just for looks..
u only need front wider fenders.. and then roll rears./
well as long as i pay my amex plat .......... lol
The rear fender flares are suppose to be used over top the OEM fenders after you cut away the top inch or 2 of metal. Your supposed to cut way the fender till about where you want the rivets of the flares to be bolted in at.
ok just got off the phone with dixon and orderd the wide front fenders and for giggles and sh*ts orderd the huge carbon gt spoiler.
will have to beat the rear fenders when my time attacks arrive i guess
