Alignment
Old Mar 5, 2007 | 08:18 AM
MD06LBP's Avatar
Default Alignment
I'm considering the Euro alignment, however I just wanted to check if anyone has their own settings that work better. This is the Euro, right?
Front
Caster Left 6
Old Mar 5, 2007 | 08:19 AM
bighead's Avatar
yup that's the euro spec. If you're not going to be doing any serious hpde/autox driving this is all you'll need.
Old Mar 5, 2007 | 08:21 AM
MD06LBP's Avatar
I autocross a bit, and I drive HARD on back roads. So I want to have the maximum stability and grip possible
Old Mar 5, 2007 | 08:23 AM
S2KinVA's Avatar
The euro spec isnt that bad tho Bill, it tightens th car up a bit. Wouldnt be a bad thing is auotocross would it?
Old Mar 5, 2007 | 08:24 AM
bighead's Avatar
you'll do well with the above, not until you have a specific need (i.e. running r-compounds) would you need more camber but toe and caster wouldn't change much... maybe a tiny bit more rear toe in but like I said, you're straight with the settings above.
Old Mar 5, 2007 | 08:25 AM
bighead's Avatar
no I did last year without problems, note my previous post.
Old Mar 5, 2007 | 08:44 AM
S2KinVA's Avatar
I dont want to note your previous post!
I Like the Uk setup personally, I ran it for the first time at the Dragon last year and wasnt use to it. Since then I've had no issue.
Old Mar 5, 2007 | 08:49 AM
cap1's Avatar
Old Mar 5, 2007 | 09:17 AM
bighead's Avatar
NOTE IT!!!!!1
Old Mar 5, 2007 | 07:32 PM
spdlmtna's Avatar
Can you literally give these "coordinates" to a mech. to do? Id like to know where
