Alignment Help
Old Apr 18, 2004 | 06:41 PM
dkmillerii's Avatar
Default Alignment Help
I'm trying to find out what the:
1. Factory alignment specs are
2. What the suggested alignment specs are for autocross
3. Local (near Catonsville, MD), trusted mechanic to go to for alignment
Thanks,
Don
G. Obadia (333, I think) sent me some of this info, but I lost it. Please help me out!
Old Apr 18, 2004 | 07:18 PM
Black Nugget's Avatar
Factory Specs are
Left Front
MIN NOM MAX
-1.5 -0.5 0.5 Camber
5 6 7 Caster
-.04 0.00 0.04 Toe
Right Front
MIN NOM MAX
5 6 7 Caster
-.04 0.00 0.04 Toe
Front
MIN NOM MAX
NONE 0.00 NONE Cross Camber
NONE 0.00 NONE Cross Caster
-.08 0.00 0.08 Total Toe
Left Rear
MIN NOM MAX
-2.0 -1.0 -1.0 Camber
0.2 0.24 0.28 Toe
Left Rear
MIN NOM MAX
0.2 0.24 0.28 Toe
Rear
MIN NOM MAX
0.4 0.48 0.56 Total Toe
Those are stock specs.. all i can help you with ... sorry
Old Apr 18, 2004 | 08:14 PM
dkmillerii's Avatar
Thanks for the quick reply. I assume that the alignment mechanic will understand all that b/c it only makes a little sense to me.
Don
Old Apr 18, 2004 | 08:22 PM
lol, yeah. he should understand it all. in fact he should have a computer that should generate all that info.. if he's a real alignment guy
Old Apr 19, 2004 | 06:33 AM
FF2Skip's Avatar
Guys and gals are using Radial Tire(or something like that) in your area. I know TubeDriver, gfactor, and SweetJ use this shop. I'll be buying my RA1's from them and they do corner-weighting. Supposedly they setup quite a few track cars.
Old Apr 19, 2004 | 06:34 AM
FF2Skip's Avatar
You might want to use the search in the Racing & Competition forum. Also look in the FAQ in the same forum.
Old Apr 19, 2004 | 09:30 AM
TubeDriver's Avatar
Yup but they don't do alignments (not sure about corner weighting). Great place to get and mount tires. Allen automotive is right around the corner (in Silver Spring). Radial Tire uses them for alignments. They are a little hole in the wall shop but they have fancy alignement racks and will do custom specs for $75. I have had them do alignments and was satisified with the work.
[QUOTE]Originally posted by FF2Skip
Old Apr 20, 2004 | 01:31 PM
333's Avatar
333
don you will need more camber than that in the rear. at least 2.5. also ask for as much caster as possible its about 6 degrees. again go to allen auto 301-587-6755.
1.5-6 f cam
2.5 r cam
0 f toe
1/4 total r toe
6 deg caster
Old Apr 20, 2004 | 01:34 PM
FF2Skip's Avatar
Are they the ones that do corner weighting?
Old Apr 20, 2004 | 06:36 PM
TubeDriver's Avatar
I don't think they do corner weighting but I am not sure. Gfactor knows a Porsche race shop that will corner weight correctly but they charge mucho bucks (approx $400).
a2l90e
Jun 5, 2014 04:46 PM
yorkies2k
Jan 25, 2013 10:25 AM
voidHeart69
Feb 25, 2011 10:57 PM
ASpec818
May 25, 2009 07:00 PM
neuro8
Jan 19, 2006 10:48 AM
