Can someone help me! Spring installation
Old May 6, 2008 | 03:17 PM
smithchaiyakan's Avatar
Thumbs up Can someone help me! Spring installation
The problem is my friend who works at a Toyota dealership couldn't get the lifting arm under my car because the arm was too long... If anyone has a place near me please let me know ASAP
I'm looking to pay around 150-180ish to install springs... Anyone wants the job let me know?
NOVA area please i live in Kingstowne!
Old May 6, 2008 | 03:54 PM
nightcrawler7188's Avatar
read the DIY and get it done for free! it's not that complicated if you can set aside a day to do it.
Old May 7, 2008 | 03:01 AM
Dude Haha It will probably pop my teeth out... I rather this be done at a shop...
Old May 7, 2008 | 03:47 AM
magikcow's Avatar
PM Bighead.
Old May 7, 2008 | 07:04 AM
yardy8301's Avatar
if you have the tools and the space to do it, i can help you do it. its not that difficult.
Old May 7, 2008 | 07:25 AM
dollar's Avatar
Originally Posted by magikcow,May 7 2008, 07:47 AM
PM Bighead.
x 1000
Old May 7, 2008 | 08:37 AM
MitsukillinS2K's Avatar
the hardest part was the drivers side rear and all you have to do for that is disconnect the fuel filler neck and move it aside. All it is is 3 8mm bolts and boom it will slide off. The only other hard part is that you have t make sure the hat over the top of the spring is lined up so that the assembly will go back in. That was the only hard part for me. It basically meant that I had to make a couple trips to the spring compressor to get it lined up.
Old May 7, 2008 | 08:56 AM
bighead's Avatar
don't forget the 10mm behind the interior trunk panel
Old May 7, 2008 | 09:47 AM
Bighead thanks for the hook up tonight!!! Will be there 7ish... Finally my S will look like it isn't on a lift kit
Old May 7, 2008 | 09:57 AM
s2kkyo's Avatar
gl ! ^_^
