Check Engine Light ON after Comptech CAI Install
Old Apr 24, 2004 | 02:32 PM
s2k paradigm's Avatar
Default Check Engine Light ON after Comptech CAI Install
Aight guys,
I just installed the Icebox into my MY04. I started it after double checking all of the connections multiple times. Sounded like it kind of choked when the ignition started, and when I rev the engine, I can only get it up to 3 grand. Seems like a rev limiter is kicking in at that point. Any advice? Has comptech f-ed up the instructions??
LB
Old Apr 24, 2004 | 02:37 PM
CHIX RULE's Avatar
Sweet girl!! Cant help ya, but need to put something in mine and maybe you could lend me a hand one of these days??
~A~
Old Apr 24, 2004 | 02:40 PM
Poindexter's Avatar
How much oil did you use on the Air Filter?
There was a little box that was attached to the factory intake - where did you relocate that?
It mostly sounds like there could be a hose out of place - or Mason installed it
Old Apr 24, 2004 | 02:58 PM
I followed the instructions EXACTLY for all the hoses...checked all the connections...map sensor etc..
same w/ the oil spray (followed instructions, sprayed liberally waited 2-3 min sprayed again...
what little box are we talking about here from the stock intake? there's only a couple big pieces that came off the MY04....could that be what's causing the CEL to come one??
LB
Old Apr 24, 2004 | 03:14 PM
brerspidur's Avatar
my knowledge is all 03 and earlier, but if its the same then double and triple check all the vacume lines, also, one of the lines has a white gizmo in the line, be aware that this line is a 1 way line, and if you put it in the right spot, it will still need to be going the right direction to avoid the CEL. i had this problem with my aem
Old Apr 24, 2004 | 03:25 PM
cool thanks brerspidur, I'll try that as a last resort...I'll be bringing it in to see Jonathan at Evolution on monday.....
*sigh*
tenblade2001's Avatar
Its the vacume lines.... they are probably swithed. Take a pic of your engine bay and post it. Get close ups of the hoses and connections. Also, wait till you have 3 bars before engaging vtec.
Old Apr 24, 2004 | 03:28 PM
Poindexter's Avatar
Anyone think it could have to do with the Map Sensor?
Old Apr 24, 2004 | 03:30 PM
maybe... but map sensor will cause it run like garbage, not throw a CEL (I think). My money is on the vacume lines.
Alex, take a close up of your connections, vacume lines for her.
Old Apr 24, 2004 | 03:33 PM
Poindexter's Avatar
Steve - my help only goes so far - taking a picture is too much work
Those two already cut into my dinner time while we were on the phone trying to diagnose it
