diff fluid change
Old Aug 2, 2007 | 06:08 PM
sparrow's Avatar
Default diff fluid change
I just crossed the 1k break-in for my new gears and wanted to swap the fluid for le607. Is anyone available this weekend or soon to help me or just give guidance? I don't mind going to a shop and paying a few bux to swap the fluid out of convenience as well. I live by andrews afb in md
Old Aug 2, 2007 | 06:47 PM
MitsukillinS2K's Avatar
just get a grease gun...drain the old fluid out and then use the gun to fill up the oil
Old Aug 3, 2007 | 03:17 AM
GPWonTan's Avatar
i plan on doing mine at a shop (i also needa get MTF changed as well). can anyone recommend one for me in northern VA?
Old Aug 3, 2007 | 04:19 AM
O-turn's Avatar
Go to the Under The Hood Section of the forum, then in the sticky portion, you will find Do it yourself threads.
Old Aug 3, 2007 | 04:35 AM
MacGyver's Avatar
I still need to do mine... how about Saturday at my place in Columbia?
Old Aug 3, 2007 | 04:47 AM
sparrow's Avatar
what time saturday in columbia?
Old Aug 3, 2007 | 04:55 AM
e3opian's Avatar
The hardest part the first time you do it is finding a 23mm wrench for the fill plug.
Differential Fluid Change
Old Aug 3, 2007 | 05:19 AM
goldenfri's Avatar
i'm planning on doing mine this weekend as well, I have done it before by just squeezing the bottle with a small hose on the tip that goes into the diff, but that really sucked and took forever and i won't do that again. I bought a pump this time, its actually really easy just take off the drain plug and drain it then replace, then fill it though the fill plug.
Old Aug 3, 2007 | 06:10 AM
sparrow's Avatar
yea, i figured there wasnt any rocket science behind it i just dont have a pump at the moment and if some1 was hopefully doing theres in the area i would've just met up with them and got it done at the same time
Old Aug 3, 2007 | 10:57 AM
nightcrawler7188's Avatar
i have the pump i used for my diff fluid change if someone wants to come pick it up. i'm in silver spring
