Got a Tech question for the Mid-A Guys!
Old Oct 28, 2009 | 01:16 PM
LeeC's Avatar
Default Got a Tech question for the Mid-A Guys!
Replaced the TCT due to having the infamous TCT sound. Yet the sound didn't go away or change whatsoever. This is my DD so I need to get on top of this ASAP.
Any Ideas guys?
Thanks!
Lee
Old Oct 28, 2009 | 01:32 PM
e3opian's Avatar
Is the sound on a cold start / warm start / both? How many miles?
Old Oct 28, 2009 | 02:23 PM
Danabis's Avatar
Had the issue when I ran mobile 1. Changed to royal purpel and it went away. Now I'm on amsoil and seems like the engine might be a little noisier (could just be me) than when I had royal purpel but still no tct sound.
Old Oct 28, 2009 | 03:21 PM
LeeC's Avatar
Sounds is both cold start and warm start all the time. 48k miles, stock car w/ a catback.
Did a compression test and got 200 200 200 120
Any ideas as to the cause? The noise sounds like head noise, nothing like bottom end, bent valve?
Old Oct 28, 2009 | 06:08 PM
e3opian's Avatar
Could be. I don't know much about the heads. But, the TCT noise is only on warm starts.
Old Oct 29, 2009 | 03:20 AM
ybadic's Avatar
what is TCT noise ?
Old Oct 29, 2009 | 04:13 AM
tacocat's Avatar
Originally Posted by ybadic,Oct 29 2009, 07:20 AM
what is TCT noise ?
https://www.s2ki.com/search/forums?query=TCT+noise
Old Oct 29, 2009 | 05:17 AM
Olegator's Avatar
do a leakdown test, do a compression test again while you are at it.
After that it should be obvious whether you have a valvetrain problem or not.
Good luck.
I can help you If you need.
Old Oct 29, 2009 | 01:46 PM
C Ory's Avatar
First, which cylinder had the low compression? 4? The last one you did?
Make sure you unplug the injectors before you do the compression test, to make sure you're not filling the cylinders with gas, which lowers compression readings. After you do a dry compression test, do a "wet" compression test. Pour about 1/2 cap of oil in the cylinder before you test it, and repeat all 4 times and see if the compression comes up.
On one of the S2000's I just worked on, one of the rocker shaft rollers was stuck. It made a loud tapping sound. Was a real PITA to figure out.
For anyone that has said Mobil 1 could be the problem, I will have to disagree. I have ran nothing but Mobil 1 in my car for 3 years, and 40k miles. Never had a single noise/problem.
I wish you were closer to me. I would be more than happy to have a listen for you. I figured out Terry's car. And I was able to figure out the noise on Rob's car.
Old Oct 29, 2009 | 01:54 PM
LeeC's Avatar
the low compression was indeed in cylinder 4.
Never used mobil1, in this car.
