HELP!
Old Jan 27, 2007 | 01:02 PM
Aze85's Avatar
Default HELP!
so.. i just installed my VAFC II and my car is acting all retarded. its sputtering and is barely driveable. i did not mess with any of the settings and they are all set to zero... can you guys tellme what to do so it willbe back to normal?
thanks!
-dan
edit: pics of the mounting position here: https://www.s2ki.com/forums/index.ph...&f=12&t=457328
Old Jan 27, 2007 | 04:42 PM
cap1's Avatar
It because your car is white Dan
If you unwire everything how does the car act?
Old Jan 27, 2007 | 08:38 PM
Insert Name's Avatar
I don't have much experience with an AFC on an S2000, but when I installed an AFC on my old GSX and in a couple of my friends supras we had to put in baseline values before we actually started "tuning" it. The supras both started acting funny after the install until we put in some base values to work off of. Keep in mind this was with the AFC right before the AFCII came out.
*Edit*
After a little research here are a few things to think about.
- How did you connect the wires? Did you solder them or use something like a vampire clamp for the hookup?
- Did you double check your wires to make sure you tapped the right wire?
- You did TAP into the wires, you didn't CUT them I hope?
Lastly, I stumbled upon the settings that you need for startup for the VAFC controller. I dunno if you did these or not but you might wanna try them if you have not.
Make sure your controller is set up for the following.
- Sensor type: 6in, 6out
- Car select: 4
- Make sure the directional arrow is pointing northeast
Read this if you have any other concerns about tuning and startup.
Old Jan 27, 2007 | 10:13 PM
Aze85's Avatar
^^ thanks alot. will look at it tomo. im sure that i did not do/check any of those
shit, sorry guys. i forgot to mention i have the plug and play harness
Old Jan 28, 2007 | 10:31 AM
Aze85's Avatar
i checked those things and it is still acting funky. hmmmmmm
Old Jan 28, 2007 | 10:51 AM
FF2Skip's Avatar
Thank you for taking the time to provide all that info.
Old Jan 28, 2007 | 11:04 AM
Aze85's Avatar
i just disconnected it right now. gonna take it to inline soon
aznprydefloz
Jul 7, 2005 06:12 PM
azn9imp
Jun 28, 2003 02:40 PM
azn9imp
Jun 28, 2003 04:36 AM
azn9imp
Jun 28, 2003 04:35 AM
Cyber Logic
Oct 12, 2001 10:12 AM
