HELP! please read and point me -> or <-
Old Dec 16, 2009 | 08:02 PM
01S2KBROSNAN's Avatar
Thumbs up HELP! please read and point me -> or <-
Hello guys and gals.
A few weeks ago i went and had my VAFC tuned by JE imports. When it was done the car felt good but weird to me cause the VTEC was now turned down to like 57** ish RPM. Now idk if its the temp or what but now in between 6&7 grand its seems like its missing or breaking up?? i was over olegs house on sat to get my fenders rolled and he listened to the car cause i thought it might need a valve job but he said no its just me thinking i am hearing things. this problem i have i am not just hearing it becasue i can feel it too and so can whoever is in the pass seat. what should i do first?? reset the VAFC, but idk how lol. Also i think its only happens at WOT and that is whats leading me to the VAFC being the prob. I just dont want to piss all that tunning money away if it could be something else.
car only has 43,*** miles on her. less than 2g with VAFC
thanks in advance to anyone who helps!!!
chris
Old Dec 17, 2009 | 03:30 AM
sparrow's Avatar
vafc's don't work if you mount them vertical lol. Hope you figure it out. Until then I would stay off of WOT
Old Dec 17, 2009 | 04:22 AM
wow 26 ppl take a look and noone has advise???
Thanks sparrow for the wise words my friend
Old Dec 17, 2009 | 04:39 AM
Olegator's Avatar
disconnect the battery for a min or two, then connec it back up and take the car for a spin...see what happends. (resets the computer)
Next advice would be to disable the vtec engagement modification alltogether. (look it up in the instructions for the VAFC)
Old Dec 17, 2009 | 04:40 AM
Nandska's Avatar
Are you using a frog harness (PnP)? If so, disconnect it and reset the ECU and let it run for a little bit (20 minutes or so). See if it does the same thing, if it doesn't, it's probably the tune.
Old Dec 17, 2009 | 04:41 AM
Olegator's Avatar
Then I'd look into your VAFC configuration....it is possible that JE leaned the car out like crazy to get the most power out of it, and now since it got colder it got even leaner so the ecu is freaking out...
...unlikely though....
Old Dec 17, 2009 | 04:43 AM
Olegator's Avatar
map sensor whack??
Old Dec 17, 2009 | 05:36 AM
thanks guys.. olegs i cant find anywhere directions to change the vtec back.. i have off work today so i am going to try to figure this out and move that tab so i dotn slame it again. lol try not to brake it off
Old Dec 17, 2009 | 05:39 AM
i want to continue to use the VAFC for its looks and gauges on it becasue its more accurate. if i reset the comp by unplugging the battery for a few minutes will this also reset the VAF to stock??
Old Dec 17, 2009 | 05:57 AM
bighead's Avatar
no, it has an internal memory. I would personally disconnect the VAFC (if you are using a pnp harness) and see what happens... if it's ok then it's the tune.
