Hub/Bearing Replacement
Hi All,
My car has started making the bad rear bearing sound and will probably need to have the right rear bearing and hub replaced. I already torqued the spindle nut to 220 ft-lbs and that helped for a bit.
Has anyone gotten this done in a shop around here? If so, what did it cost?
Any shop recommendation in or near Montgomery County?
I am debating trying to do it myself but will need to buy a couple of special tools so I am wondering if it is worth the effort and climbing up the learning curve to do it. If it would be about the same cost after buying the tools, I will probably just have a shop do it. (Although I would have the tools for doing the left bearing in the future
Thanks for any information you can provide.
Greg
)Thanks for any information you can provide.
Greg
Originally Posted by quicksilver,Sep 22 2009, 04:57 PM
Hi All,
Greg
Greg
Hey i had Both my hubs and bearings replaced for 200...
i'm not sure if you got qoated for just ONE side for 150.. but all i did was give them the hubs, bearings, chilled while they worked on the car and paid my 200 and left.. I live in nova.. shop is off of route one near fort belvoir.. if your interested..
Originally Posted by ECale3,Sep 22 2009, 07:33 PM
What exactly is that sound like...as I have a mystery clunk in my rear end that I can't find.
Originally Posted by quicksilver,Sep 22 2009, 05:49 PM
It is a bit hard to describe. It started off as a loud clicking sound when I would back up and then move forward ( I read someone describe it as sounding like two marbles hitting, but mine sounded more like billiard balls hitting). I read on the site to torque the rear axle spindle nuts to 220 ft-lbs. That got rid of the sound for a while but then it came back. Now, the right rear is making a sound like something is rubbing that is speed dependent. I thought it might be the brakes but the sound does not change when the brakes are engaged and I had the rotor runout checked and the pads are still in good shape. Also, the sound is louder at low speed and when I am making a left turn. Hope this helps, not sure if the sound you have would be the initial click that I heard.
Quicksilver,
That does sound like a bearing. You'll usually hear more noise in a turn when the bad bearing is on the outside of the turn.
My dealer charged $540 for the right rear bearing and hub replacement. My left rear is going but I now have a hydraulic press and monster size torque wrench so I'll do it myself. The bearing and hub alone are about $200 from Honda.
The best way to do it is pop the 3 ball joints and take the knuckle (with hub and bearing) to a dealer, shop, machine shop,etc. and let them press out the old bearing and hub and press in the new. It should only cost about $40.
$40-$50 per side
Thanks for the information everyone. I found I can get the parts for about $160 online. I would have to get a special tool to pop the ball joints. The tool is about $150.
Based on what David (yeaitsahonda) and HMFIC mentioned above, I can get a shop to do the labor for about $100-$150. If I go to the dealer, it will be over $500 (parts and labor).
Either way it will be at least $300 or so to do it this time but if I do it myself, if the left side goes bad too, I will be able to fix for less than $200. If one is shot, will the other be far behind?
Has anyone done this themselves? How hard was it? I found a write-up of the proceedure in under-the-hood FAQ section and it does not seem too bad. On the other hand, it is something that I would not want to mess up!
You can use a generic balll joint popper. Get them online for about $25 from harborfreight.com. It's not that hard.
My right rear went about 4 months ago and now the left rear is makiing noise, so it wouldn't hurt to do both.
