misfires!
Old Jan 17, 2007 | 04:21 PM
SWIFT2000's Avatar
Smile misfires!
Hey guys and gals,
Just wanted to share a problem i've been having with my S. When i'm under heavy acceleration my car starts to miss really bad. It starts at about 5,000 rpms and continues through vtec. I've changed the map sensor and reset the computer and it didn't work. Normal driving is fine, the car starts and runs fine. Checked my plugs and they look fine, (changed them about 9,000 miles ago) i torqued them down properly aswell. Could it be a coil pack? Any input would be great.
thanks in advance for any help.
Bobby.
Old Jan 17, 2007 | 04:22 PM
SWIFT2000's Avatar
o, and no cel...
Old Jan 17, 2007 | 04:28 PM
FISH22's Avatar
no cel??? i hate stuff like this. it can be the coil packs, but those are just way too expensive to just change. this is a far shot, but maybe a bad tank of gas. is there any smoke coming outta the back?
Old Jan 17, 2007 | 04:32 PM
SWIFT2000's Avatar
Third tank of gas since it started, as far as smoke, no more then normal.
Gotta love the 00,01 ecu's
Old Jan 17, 2007 | 04:35 PM
FISH22's Avatar
try reseating the map sensor connection....
Old Jan 17, 2007 | 04:38 PM
irock aypee one's Avatar
best way to start troubleshooting is to scan for dtc's. even though the MIL is not illuminated, the computer can still store a dtc. if you have access to a diagnostic tool, i would advise you to start there.
if you suspect a coil pack is failing, you can try starting the engine and pulling the plug from each coil one at a time. if the engine starts to misfire each time you disconnect a coil, you know that one particular coil is still in working order.
this "backyard test" is not the correct way to troubleshoot, but it works if you dont have access to dmm's to test various electrical parts or a diagnostic tool to read data lists. it can also be used to test fuel injectors.
a few months ago, my integra GS-R started to misfire at 5500rpm and vtec wouldnt engage. the MIL was not illuminated, but there was still a dtc stored for a Knock Sensor.
Old Jan 17, 2007 | 04:43 PM
CaptKirk's Avatar
Could it possibly be bad/clogged injectors?
Old Jan 17, 2007 | 04:55 PM
SWIFT2000's Avatar
[QUOTE=irock aypee one,Jan 17 2007, 05:38 PM] best way to start troubleshooting is to scan for dtc's.
Old Jan 17, 2007 | 04:57 PM
SWIFT2000's Avatar
could be
Old Jan 18, 2007 | 07:43 AM
TepEvan's Avatar
Sorry about your probs and I'm no help, but I have some dumb questions.
What's a DTC?
What's a MIL? (like a check engine light?)
