NEED SERIOUS HELP! PLEASE
Old Sep 20, 2010 | 01:10 PM
wills2kates's Avatar
Default NEED SERIOUS HELP! PLEASE
Hi guys,
I just picked up this 01 s2k with 91xxx bout 2 months ago. i drove my car to work last Friday, while i was driving CEL came on. When i got home i did the obd scanner and it's showing p1457. So i went online and did some research and came up with gas cap thing. so i erased the code went for a little drive and cel never came back on but i noticed the car was stuttering a little, So i thought it's nothing serious. The next morning i started my car i got this rough idle and exhaust poopin noise. So i went for a little ride, my car drives like crap looks like the car is losing power and the cel came back on. I got home plug in the obd scanner and came up with this:
P0302 - cylinder 2 misfire detected
P0304 - cylinder 4 misfire detected
P0301 - cylinder 1 misfire detected
P0303 - cylinder 3 misfire detected
P1399
To all the s2k gurus in Mid-A, i need some your help or advice. What do i need to do to fix this problem? I suck @ fixing car, basically only know how to change oil. Also is it safe to drive the car like that? this is the only transport i got have to travel bout 3 miles a day to work.
Any help is greatly appreciated
Will
Old Sep 20, 2010 | 01:24 PM
e3opian's Avatar
If it was one cylinder I would start with bad coil but all of them?? Have you posted this in Under The Hood, yet?
Old Sep 20, 2010 | 01:53 PM
Not yet, i thought i would come here 1st to see if anyone local had ever experience the same problem. well, i just talked to my boy that work @ herson in rockville, he's going to check it out tmr. i'm crossing my fingers for nothing serious. i'll keep u guys posted once i find out what's wrong.
Old Sep 20, 2010 | 02:14 PM
01S2KBROSNAN's Avatar
I don't say this but i think something fishy happened. It's odd to me that your gas cap was on incorrectly and then you have misfiring problems i hope some a hole in put something in your gas tank.
Old Sep 20, 2010 | 02:41 PM
Roflcopter's Avatar
you don't say what? why do you hope someone put something in his gas tank? that's mean.
Old Sep 20, 2010 | 03:21 PM
That's not what it was supposed to say, i wrote that from my drips using the talk to text thing... it'd new to me. I don't wish that upon anyone ever... its sounds fishy to me, like its possible it could have happened.
G L. I hope this is not the case.
Old Sep 20, 2010 | 05:58 PM
Insert Name's Avatar
Have you been driving it hard previous to this occurrence?
Just throwing it out there. Could be a MAP issue. Simple fix, common problem that causes a lot of weird issues. Start with the free fixes before you waste $ and time.
https://www.s2ki.com/forums/index.php?showt...&#entry15425767
Old Sep 20, 2010 | 07:16 PM
TopGear's Avatar
There is an entire thread about misfires in UTH. Basically, there are a ton of different things that can lead to the codes you're getting (bad gas is a possibility). I'd have a read, and go from there.
Here ya go: https://www.s2ki.com/forums/index.php?showtopic=659930
And good luck!
Old Sep 21, 2010 | 06:34 AM
shittles's Avatar
with TopGear and Insert Name, as there are a lot of reasons your car can throw those codes.
Old Sep 21, 2010 | 08:23 AM
I understand, thanks a lot for the info guys. Hopefully just spark plugs and coilpacks. I have a friend that used to own an s ran in to the same problem, he told me he just replaced coilpacks and spark plugs will do the job.
