Need work done.
Old Feb 16, 2014 | 12:50 PM
mandrocortes's Avatar
Default Need work done.
I recently bought a 4 point roll bar from Rockstar Auto Garage. I have a general idea of how its done but I much rather much have someone with knowledge do it. My s is an ap1 with stock body/no hardtop, I am willing to pay (hopefully not too much because i can assist with the installation) Located in Gaithersburg MD and can commute. Thanks in advanced guys. Want it done before the O.C. trip we have in March lol
Old Feb 16, 2014 | 01:11 PM
gfacter's Avatar
What brand bar? A 4 point bar is a time consuming project and requires extensive drilling, cutting and trim work. Usually takes more than a day.
Old Feb 16, 2014 | 02:32 PM
It's from rockstar auto garage. Comes with all the hardware. Its this exact roll bar.
https://www.google.com/search?q=rock...F%3B1600%3B902
Old Feb 16, 2014 | 05:27 PM
postman's Avatar
To install that bar I would typically charge $400 assuming you have all mounting bolts as well. If you want plastics reinstalled (cut to fit) add $200.
Also be sure you have seat belt guide tabs on the bar, so you can reuse your factory seat belts.
Old Feb 16, 2014 | 06:36 PM
The bar comes with the tabs welded on. How much would you charge if I remove all the plastic before dropping the S off?
Old Feb 17, 2014 | 08:07 AM
postman's Avatar
$300. You will need to have everyhing behind the seats removed including roll hoops. Only thing in there should be tbe bulkhead brace. Though I'm fairly far from you. In chambersburg, PA. Usually for a rollbar drop off Friday at my house and pick up on monday.
Also just so you are aware there will be holes drilled and panels cut in the rear fender wells to install this. Just making sure you understand that as some people are clueless on the extent of an install like this.
Old Feb 17, 2014 | 08:22 AM
I found someone to do it for $100. thanks alot tho man
Old Feb 17, 2014 | 10:36 AM
gfacter's Avatar
Is that car going to the track or is this just for show?
$100.00? Have they installed a bar like this in a S2000 before? Good luck.
Old Feb 17, 2014 | 10:55 AM
Yea he has, just helping me out. And its for show but i want it for safty as well because i'm going to be boosting soon
Old Feb 17, 2014 | 12:50 PM
duffman13's Avatar
I did mine myself in my driveway last spring, took me about 7 hours. I hope he knows what he's getting into.
