Problem with Vtec?
Old May 24, 2007 | 10:18 PM
Rprsntng757's Avatar
Default Problem with Vtec?
My vtec really seems to lag, especially in first gear around 7k rpm, then it hits hard as usual. Has anyone had this problem, or know what could be wrong?
Old May 25, 2007 | 04:29 AM
bcohan's Avatar
Was the car warmed up first?
Old May 25, 2007 | 04:37 AM
sixsevenone's Avatar
got the same problem!
Old May 25, 2007 | 05:08 AM
goldenfri's Avatar
I'm just taking stabs in the dark, but have you checked your oil level? That can do wierd things to VTEC if its too low.
Old May 25, 2007 | 05:13 AM
level is good, it seems like the rev limiter kicks in on mine
hmmm, it shouldnt do that @ 7000rpms on 1st
Old May 25, 2007 | 05:40 AM
civicguyinva's Avatar
Sounds like the car wasn't warmed up enough and disabled vtec. Make sure temp gauge is at 3 bars and try again.
Old May 25, 2007 | 05:44 AM
FF2Skip's Avatar
Also, at lower speeds and a clogged air filter, you may not be getting enough air momentarily... causing it to stumble. This is in no way a diagnosis; just a thought.
And I'm not going to ask why you need to hit VTEC in 1st gear either.
Old May 25, 2007 | 05:49 AM
no need!
thanks guys, i think i do need to change out the filter, and wait for the three bars!
Old May 25, 2007 | 10:47 AM
Insert Name's Avatar
Becuase he was trying to catch Dom!!
Old May 25, 2007 | 10:57 AM
