SPC Adjustable Ball Joint Install How-To
Old Oct 1, 2007 | 01:16 PM
robrob's Avatar
Default SPC Adjustable Ball Joint Install How-To
I recently installed SPC adjustable ball joints in the front of my S and I documented the install. The install also shows how to remove the brake dust shields.
Here's the link: S2000 SPC Ball Joint Install How To
Let me know if you have any questions or corrections.
Rob Robinette
Old Oct 1, 2007 | 01:34 PM
FF2Skip's Avatar
Very nice, Rob. Sunday, while talking to Toan, he mentioned how one could angle the plate such that an increase in caster and camber could be possible. Lots of caster allows one to run less camber in a straight line, while increasing dynamic camber upon turn-in. More-for-less tire wear and better straightline braking.
Old Oct 1, 2007 | 01:53 PM
robrob's Avatar
Now you tell me about the intentional caster inducement...
I guess I can always press the bottom plates out and try again. I assume you would want to move the ball joint inward for more camber and to the rear to add caster so a nice diagonal orientation would get the job done.
Rob
Old Oct 1, 2007 | 01:56 PM
FF2Skip's Avatar
Rob
Sorry, FlyBoy, I just found out myself.
You don't want to go 45*, but some angling could benefit both. I can't say how far to go- Toan might be the one to ask.
Old Oct 1, 2007 | 03:20 PM
Hobbs5313's Avatar
Nice write up Rob.
Old Oct 2, 2007 | 05:13 AM
FF2Skip's Avatar
Rob, I'm putting my car on PTuning's dyno Thursday morning(I'm actually hoping for low numbers ). I will ask Toan for more specifics.
Old Oct 2, 2007 | 06:38 AM
robrob's Avatar
Cool, let me know what he says and I'll add the info to the how-to.
Rob
Old Oct 4, 2007 | 06:07 PM
robrob's Avatar
I finally got a good alignment with the SPC camber kit. With me in the driver seat my shop was able to get:
Front
Caster 6.8 degrees
Camber -2.8 degrees
Toe 0
Rear
Camber -3.3 (no camber kit in back)
Total Toe In 36"
I have the SPC balljoints set at maximum negative camber (full in), but the stock adjusters have plenty of camber adjustment available if needed.
Rob
Old Oct 7, 2007 | 05:35 AM
robrob's Avatar
Here's a pic of what full lock looks like with my alignment:
The car drives nicely on the street. I'll let you know how the alignment feels on the track as soon as I can.
Rob
lowkey ap1
Jun 27, 2011 04:03 AM
1point3_to_2point2
Mar 20, 2011 12:07 AM
Ben22
Socal Swap Meet
Aug 21, 2009 08:04 PM
robrob
Aug 16, 2009 05:44 AM
geovong
Sep 28, 2006 01:13 PM
