tire fix?
Anthony, if the tire is only being plugged, the rim is never in any danger... unless they drop it. Plugs should only be for temporary use though. If the tread depth is still good on the tire and the hole is not in the sidewall or close to it, you can have them dismount the tire and patch from the inside. It is at that point that you may have concerns.
I can't remember what rims/tires/sizes you're running. The lower the profile or stiffer the sidewall, the harder it is to mount.
i work on andrews, and can plug u'r tire up for free.
just swing by my house in upper marlboro.
u just have to buy the tire plug kit from walmart :]
it's basically 2 T handles and 1 sticky brown doo doo.
DO NOT BUY THE ONE YOU PATCH FROM THE INSIDE. !!!
Originally Posted by visionism0,Aug 31 2007, 09:22 AM
if you want your tire patched from the out side,
Misinformation is the devil.
I've had to use plugs before. They're easy and a quick fix. For safety purposes, it should be noted that they are FOR TEMPORARY USE. My insistence is not to shoot you down- it's for safety reasons.
I was just offering him free service to patch his tire if he needed it.
It is recommended the best way to PATCH a tire is from the inside.
But you are correct.
Patches are only temp solutions till you have cash for a tire.
but anyways skip.
go away. :]
Originally Posted by FF2Skip,Aug 31 2007, 07:46 AM
Thank you for trying to help.
Esp for how we drive our cars; plugs and patches are FTL.
FYI i never plug my car.
