Vortech Question?.....
Old Mar 10, 2007 | 10:00 AM
O-turn's Avatar
Default Vortech Question?.....
I got underneath my car today and noticed directly under the supercharger the frame had oil on it, nothing on the ground, but there was a decent amount under there, Checked the dipstick, quart low, nothing out of the ordinary. so I look up near the oil filter and on the back of the blower itself, I see an empty threaded hole with a tiny drip, nothing steady, maybe a drip every 10 minutes. The whole underneath of the engine had oil residue on it, as if this has been going on for a bit. The motor was fine, dry and unharmed from sight, car feels fine as well. I changed the oil, started the car, nothing. Im gonna drive the car for a bit and see if this same thing happens, I just wanted to see if anyone has had experience with this? ANY HELP IS APPRECIATED!!!!!!
Thanks alot!
Brian
Old Mar 10, 2007 | 04:06 PM
gfacter's Avatar
My comptech leaked a bit from the braided oil return line, I replaced it problem solved.
It was a Pita to replace.
Just make sure you are not loosing a lot of oil
Old Mar 10, 2007 | 04:36 PM
O-turn's Avatar
Ok, I drove 130 miles today, hard miles...
I come home, check the oil (that I just replaced) and it looks to still be at capacity. Now it IS 9 at night, so its kinda dark, gonna check again in the morning. Thanks for the advice george, Im gonna check all my lines this week and try and get a picture of what I think is the problem.
Old Mar 10, 2007 | 08:45 PM
civicguyinva's Avatar
My Vortech leaked from several points originally.
Like George said, check the steel braided oil lines. Both ends tend to leak. Also I suggest checking the vtec solenoid gasket area. That is another common Vortech leaking location. Hopefully you find it because those bearing get pretty angry if they are oil starved.
Old Mar 11, 2007 | 08:16 AM
AkA S2K's Avatar
sell everything = ap2
Old Mar 11, 2007 | 08:51 AM
tacocat's Avatar
Make sure you get the new oil into the little hole on top and nowwhere else.
bexiga
Feb 20, 2011 03:23 PM
si2ik
Apr 6, 2010 05:52 PM
sik00
Aug 5, 2008 06:01 PM
O-turn
Jun 28, 2007 11:36 AM
asukadc
Jun 10, 2006 10:20 AM
