Wheel stud change
I'm in the midst of having to replace the wheel studs on the rear passenger side and am finding that it is pretty tricky and wondering if anybody's got experience with this and could point me in the right direction
This should help a bit if not a lot. http://www.robrobine...2000Bearing.htm, it's Rob's website and I think he don't mind if we all share the magnitude of knowledge he created. Check it out and good luck.
Yea, I don't know of any way to change out the studs without pressing out the hub. I would recommend you replace the wheel bearings when you do it. I like the Autozone Timkin bearings for about $36 each.
Originally Posted by robrob
Yea, I don't know of any way to change out the studs without pressing out the hub. I would recommend you replace the wheel bearings when you do it. I like the Autozone Timkin bearings for about 36 each.
I feel your pain. Every time my STi is touched by someone else. (State inspection.) I discover cross threaded wheel studs next time I swap wheels. I'm up to number 5.
I am rocking mis-matched wheels right now because i discovered number five on a rear wheel after doing number 4 up front. A "two-for." I just left it and had to walk away. I was ready to burn the car to the ground.
