Mid-A Swap Meet Member Classified Ads in the Mid-A Region
FS: OEM and aftermarket part out
Old 07-09-2013, 05:23 PM
9k_on_occasion's Avatar
Default FS: OEM and aftermarket part out
Contact: PM
This is the thread where I sell off all my extra parts.
AP1 metal grille insert. $50.
Rubber edging, steel insert for the AP1 bumper hole. I wire brushed the metal and repainted it. Chewed up the rubber in some spots where I got overeager with the brush, but that's mostly on one side.
Defroster harnesses and button bank for MY 2000 vin below 5730. Check the date on your door sill. If your car was not built in 1999, this probably won't work in it.
32204-S2A-A00 and 32205-S2A-H00
$75
OEM leather-wrapped shift knob. $20 It isn't as scratchy as it looks in the pics. Other two knobs are sold.
SRS airbag harness for 00-05. Worked when I took it out of the car. $25
77961-S2A-G00
Freebies! Come and pick up the items below. I am willing to deliver in Mid-A for a fee.
PVC hardtop stand
Has disconnects in the middle to take it apart and fit through a standard door frame.
Black door card inserts. No rips or tears.
Tan leather interior trim. These are the short pieces that go behind the seats, below the vent panels. The one on the right does not have the back padding.
Black carpet floor pans. Good condition, no rips or stains. There are some small cuts in the driver's side at the floor hump and under the seat. Didn't want to take the trash bags off and deal with the glue for the pics.
passenger side hump
driver side with cuts
9k_on_occasion is offline
Old 07-10-2013, 04:51 PM
Added Spoon X brace, Gendron swaybar, and Password JDM intake stuff.
Old 07-13-2013, 11:15 AM
Added Rick's header and Konis.
Overflow from SOLD stuff below.
Random box of Honda parts. Mostly clips and small bolts, but there is a defroster button and a plastic panel in there. Sold for $12.
OEM tophats. Sold for $35
Shift knobs. Mugen aluminum 'dildo' and OEM titanium knobs. Sold for $60.
Alcantara shift boot. Sold for $15.
Old 08-07-2013, 03:12 PM
SOLD stuff here:
Front heat shield
sold for $100
Side heat shield
sold for $100
Spoon front X brace. Has a small rust spot or two. I'll probably just repaint them.
Sold for $120
Password JDM carbon fiber intake and modified Coastal Metals cooling plate.
Sold for $600.
Asura 3" dual exhaust, round tips. I painted the canisters matte black (not flat, not gloss).
Sold for $750.
Rick's stainless steel header. A few of the bolts for the heat shields broke, so I drilled them out and retapped the holes.
Sold for $175.
Gendron 1 inch *solid* fsb front sway bar. This thing is a beast.
Sold for $400.
GT Motoring alcantara slipcover for the '00-01 center tunnel. This will fit over the carpet, and you can kinda make it work over the leather cover but not well.
Sold for $30
Full CR tonneau conversion parts. Everything you need: the tonneau itself, two side filler panels for when the hardtop is off, three rear rails, two side plates to mount the hardtop side catchers, two brackets to replace the hardtop bumper brackets, and three bolts plus a cover plate to secure the tonneau itself.
Sold for $725
Moddiction short shifter. The stock shifter doesn't feel long until you put this in, then it's like a truck. The short shifter has a rubber ring or something starting to pop out of the shifter body, but it doesn't hurt anything.
Sold for $125
Bride RO (?) seat rails
Sold for $220.
These don't have any Bride stickers, so I can't promise they are actual Brides. They certainly look like it, and came off a set of Spoon seats that are recovered Brides.
Custom-valved single-adjustable Konis.
Sold for $750.
These were revalved by ProParts to a spec developed for B-stock autocross. Even if you don't do autox, these are awesome on the street. Aside from the usual shitty Koni paint, everything is intact. No stripped threads. Includes tophats, spring perches, Koni bumpstops, and hardware.
#s 04407, 04408, 04409, and 04410
Muteki black open lugs. Some surface rust, but entirely usable. The socket has no cracks or splits.
Sold for $20.
Bridgestone RE-11s
2 each 205-55/16 and 225/50-16 stock AP1 sizes.
Tread is good on all four, no gashes, lumps, or patches.
sold for $200 picked up
OEM Berlina black hardtop w/side catchers. Sold for $3200.
Hardtop was purchased new from HTG back in 2007. All original, never repainted or wrapped. There is one small ding in the center of the roof, and the inside liner creased in one place along the back glass. Comes with the oem side catchers and the bolts to mount them.
Three JDM BBS wheels (fourth one cracked a spoke). Two fronts and one rear, stock AP1 sizes. $150 each, or $400 for all three.
They have some brake dust splotches and some nicks from the tire machine in the barrel, and a bit of cone rubbing on the face. One of the fronts does have some curb rash.
front
front w/curb rash
rash
rear
inside, typical of all three
Pale yellow USDM corner diffusers. These were once clear, but didn't stay that way. $10.
USDM amber corner diffusers. $10.
Old 08-11-2013, 01:17 PM
Added short shifter and boot.
Old 08-21-2013, 08:53 AM
Sold the intake and X-brace.
Old 08-22-2013, 04:23 PM
Added (and sold) seat rails.
Old 11-10-2013, 05:20 AM
*bump*
Have header, exhaust, swaybar, konis, shift boot, and lugs. Added AP1 grille insert.
Old 11-15-2013, 06:20 AM
Asura exhaust is sold.
Old 11-21-2013, 09:27 AM
Tires tires tires.
Quick Reply: FS: OEM and aftermarket part out
