MidWest S2000 Club Kansas, Nebraska, the Dakotas, Missouri, Iowa, and Minnesota
Computer Help!
Old Mar 13, 2006 | 06:29 AM
CUL8ER's Avatar
Default Computer Help!
Can someone please help? I have sent this message to support@s2ki and have not heard back from them. On my computer @ home I cannot connect to the s2ki site, when I try I get the following error message:
The XML page cannot be displayed
Cannot view xml input using style sheet. Please correct
the error and then click the Refresh button, or try again later.
System does not support the specified encoding.
Error processing
Old Mar 13, 2006 | 07:38 AM
BlackNightmare's Avatar
i get that sometimes. it usually works next time i try to access it, not right away, but hours later, i thought it just had something to do with there site?..who knows.
Old Mar 13, 2006 | 07:53 AM
JulieU's Avatar
Administrator
Hmm, have you tried using Firefox?
Old Mar 13, 2006 | 08:40 AM
CUL8ER's Avatar
Yes that is what I have at work and it works fine. I use the SBC Yahoo wed browser @ home for the security with the kids,e-mail etc. It use to work until recently (last 2 weeks). I would think there is someway to correct this short of changing the browser?
Old Mar 13, 2006 | 08:53 AM
JulieU's Avatar
Administrator
IDK then. I tried searching in Site Info with little results. You might get a quicker response posting in that forum (versus e-mailing support@s2ki). Or, maybe this has someshing to do with it...
Originally Posted by cthree,Feb 18 2005, 02:55 PM
I can access the site from work but not from home (or vise versa)
The most likely problem here is that your ISP is using an IP address block which has only recently been assigned. We screen out addresses which aren't assigned to anyone. This list get updated periodically but may be out of date. If you have this issue make sure none of the issues above exist and then let us know. Give us your IP address if you have it.
^ Found that in the Site FAQ thread.
Old Mar 13, 2006 | 10:35 AM
8BALL's Avatar
I get this at times also from home. Without making any changes to my home desktop/laptop, the problem goes away on it's own.
Give it a try again this envening and let us know if your still having the problem
Old Mar 13, 2006 | 10:51 AM
CUL8ER's Avatar
O.K. However this has been going on for about 2 weeks now. I did post in site info as Julie suggested, maybe someone has tacked this problem before and will see my post or get lucky and it will correct on its own. Thanks.
Old Mar 13, 2006 | 11:33 AM
8BALL's Avatar
Have you made any changes to your PC in the past few weeks?
Old Mar 17, 2006 | 08:36 AM
CUL8ER's Avatar
The problem is now fixed. The 2wire modem provided by sbc was having a problem reading the site. We reset the modem now it works, therefor I will close this topic. Thanks for the suggestions!
SilversS2000
Apr 3, 2009 01:27 PM
Lainey
Aug 5, 2007 04:35 PM
Lionheart
Jun 21, 2007 11:23 PM
CUL8ER
Mar 17, 2006 09:29 AM
