Nevada S2000 Owners Las Vegas, Nevada and area
Bike Carbs...
Old Feb 20, 2006 | 06:21 PM
Zzyzx's Avatar
Default Bike Carbs...
So I have a new bike, a 2001 Suzuki Volusia 800... with a carborator. and i'm having a little trouble with it. First off before I messed with it, the bike refused to idle with out the choke on, and it would sputter at low throttle settings, such as when you frist get the bike moving or when cruzing at low speeds. The Factory service manual (and some friends) said clean to the pilot and main jet, so I pulled the carb and cleaned the jets. no big deal. NOW, with every thing back on the bike I cant get it to Start, or rather I can get it to "start" but only with half throttle on and it sputters horriblly + its spewes grey/white smoke...
So what did I do wrong?
Old Feb 20, 2006 | 07:37 PM
Ludedude's Avatar
Administrator
I'm not familiar with the Volusia; is this a water cooled bike?
Old Feb 20, 2006 | 08:56 PM
Zzyzx's Avatar
ya water cooled + shaft driven, the bike only has 12,000 miles on it too.
Old Feb 21, 2006 | 08:13 AM
Ludedude's Avatar
Administrator
Ouch. When I hear white/grey smoke in a water cooled machine I immediately think head gasket. Other things to check that might cause a crappy idle, sputtering and a lack of power include vacuum leaks and timing. I'd also check the plugs and replace as needed. Don't know what ignition system you have in that thing but check the plug wires and any connections to coil packs etc.
Old Feb 21, 2006 | 08:15 AM
Zzyzx's Avatar
I think I figured it out this morning.... I may have reversed the fuel lines from the ERG valve and the fuel pump going in to the Carb..
Old Feb 21, 2006 | 09:01 AM
Ludedude's Avatar
Administrator
Doh!
Old Feb 21, 2006 | 12:43 PM
Zzyzx's Avatar
So I pulled the plugs at lunch and they were well, very wet.
pputkowski
Oct 13, 2009 01:22 PM
bigmac834
Oct 8, 2007 12:59 PM
jah
Dec 6, 2006 09:40 AM
RED04S2k
Sep 15, 2004 09:16 AM
