Nevada S2000 Owners Las Vegas, Nevada and area
Project s13k Part II
Old Jun 17, 2010 | 12:13 AM
RedLineS2k10's Avatar
Default Project s13k Part II
So to give a quick summary for everyone, i was a proud owner of an 02' suzuka blue ap1. One rainy day in vegas, the street vanished underwater, and with it vanished my intake directly into a puddle..Apparently 11:1 compression doesnt like water : ..I didnt even have 40,000 miles on it So i looked at my options and put it on craigslist. Four days after that the car was in Cali and i owned a sick little drifter
The car-1994 Nissan 240sx Vert-Silvia Conversion
Power-
F20C powerplant with f24c stroker. k24 crankshaft, h22 rods.
Stock head, Brian Crower Stage 3 exhaust cam
Garret Gt2860rs
STR log manifold
Tial 38mm wastegate
Custom aluminum 3.5" exhaust
GReddy Trust Titananium muffler
GReddy Trust Intercooler and custom elbows
Setrab 23 pass oil cooler
Setrab 8 pass power steering cooler
GReddy oil catch can
Custom Intercooler piping
Custom overflow tank
C&R surge tank
C&R dual pass radiator
Aem adjustable fuel pressure regulator
Stock fuel Rail
AEM MAP sensor (i think)
RC 750 Injectors
Custom aluminum radiator piping
Okada Coil packs
NGK spark plugs
AEM EMS (10-951) series 1 plug n play w/ map trim switch
Blitz dual SBC boost controller
Whats holding the power-
Stock Ap1 transmission for taller gear ratio
ACT lightweight flywheel and race clutch (not sure what stage)
Custom aluminum driveshaft
Custom motor and transmission mounts
Apexi EXV Coilovers
Full race bushings all the way around car (dont know the brand)
Peak Performance suspension components on the car
Inner Tie Rod
Tension Rods
Toe Rods
Upper link
Camber arm
Cosmetic & ICE
Origin Front Bumper
Origin Rear Bumper
Julius Racing Side Skirts
Origin 30mm front fenders
Origin 50mm Rear fenders
Work Emotion 18x9.5 with Falkens
MB battle wheels (rear) 18x9.5 with falken
Custom Roll cage
Project MU 4 piston 4 pad front brakes (5 lug conversion)
Sparco Evo Seats (both)
Sparco 5 point racing harness
Sparco Wheel w/ quick realease
STRI guages (oil pressure,water temp,boost, rpm (not hooked up), AEM wide band, and im missing one i think?
Custom shift bracket w/ custom shifter
So i got the car, and there were a few things that needed to be done. New manifold, some cleaning and re-painting. The car ran funny when i got it, and he had said the injectors might be clogged. I took the car to be tuned and we were having issues on the dyno, so i came back home and was stumped as to what it could be. So i finally pull the injectors and out falls aluminum shavings from when the fuel filter was flared. I mean metal was dumping out of these injectors. I tried my best to get what i could out and out them back in, and presto the motor sounded amazing!.
I sent the injectors off to RC, and of what i saw next kinda blew my mind lol. The report they sent me back was quite astounding. I didnt have one injector running at its full potentinal. One was dripping and another was just clogged. So they came back within days and headed back to the dyno. For the first time ever i heard this motor hit the rev limiter and i was stoked!! I made well over 300tq instantly. As we began to progress further and further through the tune, we went for the numbers pull and the problems started. The boost was turned up, and BLAM!! out shoots the dipstick straight out of the valve cover, and sprays oil EVERYWHERE. We shut the motir down and thank god nothing caught on fire, and let things cool for a second. We start back up and smoke is pouring from the catch can. We check spark plugs, and oil and what not, and then do the compression test. Needless to say i didnt even clear 170psi on any cylinde.. The highest i hit was maybe 160psi.
So i tow the car back home and began the process of taking it all apart thinking my rings are just fried and the motor is prolly shot. We start pulling pistons and to my amazement the rings are actually intact, but here come chunks of ringlands tinging on the ground as we pull the pistons out.
At this time i am both horrified and glad all at once. The reason...I had not a clue waht type of condition this motor was in. I mean lets face it ,its a drift car and the guy who drove it was a mad man behind the wheel with then nick name "big smoke" lol. Now with all of this taken apart, i now know what needs to be done and what the end result will be. As most of you have seen, i was trying to sell this motor thinking the cylinder walls are done. Well i had 2 machine shops check it out and i was told to rebuilding it would be fine because of the miles this motor will see.
I have one tiny nick in cylinder two im worried about but fixing that is in the process. i believe a little bit of sanding or a file will fix it, its not even to the point of catching a nail on it.
So the pistons, rings, bearings, head gasket, and a few other things are being ordered tomorrow
Im going with stock again, because 1) the price and 2) im running very little boost and the car will be driven 2-4 times a month.
The re-build is costing around $600 and thats for basically everything.
Here some pictures for you guys and will continue posting as the build progresses.
This was what i started with..this car was BONE stock (not even tint) when i got it
This was what a gallon of water will do to your block. Beware CAI members!!
This is my new baby
Heres the new manifold on the car this was only $160 and i havent had a problem with it yet
We had to reclock the downpipe because the new manifold angle the turbo a bit more
I need new seat covers bad!! these are so sun stained, and it has tan lines from the seat belts lol
Beautiful
Right after i got the car, rust build up, dust, and just sitting there for two year, the car needed some TLC
Just to give u an idea of the rats nest behind the dash
AEM baby!
Well i wanted a horn on this thing so i went to a junkyard and yanked a delco remi off a 85 F250 lol
Dont make fun of the little guy now
Project MU baby!!
Just a glimpse of the motor after it was painted.
Didnt realize the clutch fork issue when taking seperating the bell housing lol, so the whole fu*** thing came out at once lol
This was some bad shitttt
Glance at the k24 crank 99mm stroke
Vtec BABY!!!!
old bumper YUCK
New bumper i picked up for $50 bucks!!! lol Origin
It looked 10x better then it did before
Not liking the color
Ahhh thats better..notice that on the hood?? thats where the oil came spraying out all over the hood lol
And of course...The FUN IM LEFT WITH!!!
heres the power i made with the pistons in that shape
Things still to be done
Tubbing the fenders, these 18x9.5 are rubbing
Modifing steering knuckles for more angle (not for a while atleast)
Paint the car (white)
Re-paint rool cage and wheels
Hydraulic handbrake
More pics to come guys. Thanks for looking!!!
Old Jun 17, 2010 | 04:19 PM
khronikal1's Avatar
sick build man cant wait til its all finished!
Old Jun 20, 2010 | 02:56 PM
S2oooNvegas's Avatar
Old Jun 20, 2010 | 04:03 PM
speedjunkie-ap1's Avatar
Thanks for the post. I enjoyed reading it.
RedLineS2k10
Feb 21, 2013 11:40 PM
jimnasty23
Oct 2, 2011 12:36 PM
RedLineS2k10
Cars for Sale
26
Feb 23, 2011 07:33 PM
RedLineS2k10
Nevada Classifieds
Feb 12, 2011 01:31 PM
JoeyBalls
May 28, 2009 09:38 AM
