Computer question
Old Nov 20, 2005 | 12:19 PM
Lainey's Avatar
Default Computer question
A friend has AOL, and just switched to Verizon DSL, for her connection and is keeping AOL.
She had some problems at the beginning, which supposedly are fixed. I think she got some bad tech advice and weird things are happening. Now, whenever she turns on her computer, internet explorer automatically starts up. So does her AIM messenger. (I know how to change that one for her.)
Is there a setting somewhere she can change so that Internet Explorer does not start up? I have looked and can't find anything, so I'm sure I'm not looking in the right place.
I just made the same changes to my Mom's computer switching her to DSL with AOL, and did not run into that problem.
Old Nov 20, 2005 | 12:25 PM
gladwins's Avatar
In the Start menu, go to "Programs", "Startup" and then delete the IE shortcut. Hope this helps!
Old Nov 20, 2005 | 12:28 PM
Cubs2k's Avatar
Which version of Windows is she using?
Try Start>Programs>Startup Folder and see if it is there.....delete it.
You could also uninstall the AOL stuff.
Old Nov 20, 2005 | 12:52 PM
Bass's Avatar
ahhh what if there are other programs in the start-up menu
i would just delete AOL from the control panel
Old Nov 20, 2005 | 01:05 PM
Lainey's Avatar
I think she must be using XP, fairly new computer. She wants to keep the AOL and sign on directly to AOL. Even if she deletes theInternet Explorer shortcut key from the start menu, would that stop an "auto log on", as that is how she is describing it.
Maybe she needs to do a "re-install" of AOL making it her default?
AOL does not always "play nice with others", that much I know.
Old Nov 20, 2005 | 02:15 PM
Bass's Avatar
she's keeping aol :YUCK!!:
ok open up internet explorer - - - then click tools - - - Then internet options - - - click the program tab - - - at the bottom there is a check box that says - check if IE is the defaul program - uncheck this box - - then click ok
close IE and open aol - - this should work
Old Nov 20, 2005 | 02:21 PM
Lainey's Avatar
Thanks Steve.
I'll call her and have her give it a try.
Old Nov 21, 2005 | 07:12 AM
mosesbotbol's Avatar
Most likely, you won't need anything in the start up menu if it's a home computer. You can "cut & paste" what ever is in the start up menu to your desktop, reboot and see what happens. If it is a negative result, just put them back in.
Old Nov 21, 2005 | 01:37 PM
dpc's Avatar
dpc
If none of the above suggestions work, you could look as msconfig. Very useful to see what programs and services are loading at boot time.
http://netsquirrel.com/msconfig/
Hope this helps.
Dave
Old Nov 21, 2005 | 01:47 PM
Cubs2k's Avatar
Hope this helps.
Dave
A Favorite of mine.......on my desktop
