Downshifted From 6th to 5th
Old Oct 15, 2008 | 02:13 PM
Imsello's Avatar
Default Downshifted From 6th to 5th
on the highway and my driveshaft broke. Is there any chance my trannmission is going to be ok.
Old Oct 15, 2008 | 02:21 PM
Cubs2k's Avatar
?? Not sure......unless you were doing 150+ not sure why you had a driveshaft failure.....with a 6>5 downshift
I guess the good news is that the shaft gave way.....no something else....
The bad news.....if the shaft broke.....perhaps something else precipitated it's destruction.
Old Oct 15, 2008 | 02:26 PM
boltonblue's Avatar
I'd agree the 6 -> 5 shift is a pretty close ratio difference.
It was probably just the straw that broke the camel's back.
Unless of course you got 3rd and not 5th, then you should be very happy it was the driveshaft that popped.
How many miles do you have on it now?
Old Oct 15, 2008 | 02:28 PM
zzziippyyy's Avatar
Was it the U joint or the actual shaft that broke, wow that car has been giving you many issues since you bought it.
Old Oct 15, 2008 | 02:30 PM
Imsello's Avatar
it only has 65k on it. downshifted and then my shifter was shaking like crazy I saw some smoke and no my tranny is leaking where the drive shaft connects to it.
Old Oct 15, 2008 | 02:31 PM
Imsello's Avatar
The other problem was air/fuel stuff so it really hasnt given me to many problems, it was my other one that I had to fix the tranny.
Old Oct 15, 2008 | 02:36 PM
Cubs2k's Avatar
output shaft bearing?
well the smoke might have been tranny oil spraying on the exhaust
Old Oct 15, 2008 | 02:47 PM
ScottyBallistic's Avatar
1st for me ???? I agree you have the strangest issues .. I thought I have heard of them all ..
I agree , unless you had 6 gear at readline , downshifting to 5th should have no ill effect .. but 6 to 3rd I can see locking the motor as it eats all the valves and snapping the shaft ..
Does the car still run normally ?
if you are leaking fluid out the shaft end of the tranny then you sheered the shaft as the hub that holds the driveshaft to is bolted on with one large nut and the driveshaft is bolted to that via 6 8mm Allen bolts .. it does not slide on like say a 350z ..
other scenario is you sheered the 6 bolts and the shaft came back and hit the hub bending the shaft and also causing a leak ..
either way sounds like the tranny is also junk
Old Oct 15, 2008 | 03:49 PM
KingzS's Avatar
wow man thats insane... glad to know you're ok and nothing major happend.
Old Oct 15, 2008 | 04:07 PM
Imsello's Avatar
well any suggestions on where to get a trannsmission? The car starts fine and runs fine just doesnt go anywhere. Clutch feels the same. With my luck im sure I need a transmission. Im beginning to really hate the s2k. This would be my scond tranny in a s2k with less than 70k miles..not good. Should have kept my 400hp Vr4.
