fender rolling
Old Sep 28, 2009 | 04:24 PM
jorgie583's Avatar
Default fender rolling
can someone recommend a shop that's good rolling fender specially s2k ones. i just got my s2k painted and i m afraid of ruining a fender again because horrible drive way
Old Sep 29, 2009 | 04:26 AM
Legal Bill's Avatar
Should have rolled before you painted. Did you ask the body shop if they could do it? I think Metro has a fender roller they bought for the club, but I'm not sure about that. Lots of folks who have tired it have cracked the apint, so be careful.
Maybe if you tell us where you live, some folks can give you advice.
Old Sep 29, 2009 | 04:38 AM
daktruckie99's Avatar
S~Factor in Metro can do it for you.
I rolled my own fenders, but borrowed the tool from a guy in Minnesota when we were at the Dragon together.
Old Sep 29, 2009 | 06:23 AM
koukikat's Avatar
Just did mine last week with an Eastwood roller. The rears are very easy to do, just use a lot of heat and go slow. I was able to roll my rears flat and pull out about 5mm without any paint cracking or ripples, they came out perfect. Fronts are trickier (if you're doing those), the way the metal tabs are create weak points in the metal on the corners of them and is very easy to cause high spots if you're pulling them at all. I only cracked the paint on one front fender and it's because I jammed the fender liner into it by accident and cracked it, wasn't even the roller. I rolled the fronts flat and pulled about 5mm as well.
I just rented the roller from Tommy at Go Tuning.
Old Sep 29, 2009 | 12:08 PM
jorgie583's Avatar
I m located in Lawrence MA, i replaced the driver side ferder with a new one from honda and its rumbing when I hit decent bumps on the roads or even worse when i try going into any bad driveways.
Old Sep 30, 2009 | 10:40 AM
S~Factor's Avatar
Thanks man.
I recommend trimming(cutting the lip) of the fender as opposed to rolling it. Trimming the fender = zero risk of messing up your fender and your paint.
It takes about half hour to do both fenders. PM me for the price... it's LESS than half as what those other big shops charge you for. I'm located in Valley Stream, NY 11580.
sofresh&soclean
May 26, 2010 02:42 PM
BlacknBlue2002
Feb 23, 2010 04:24 PM
REVN29K_LAC
May 2, 2008 06:49 AM
skibum
Nov 1, 2007 04:17 AM
KAI-MIKAZEE
Sep 20, 2006 06:49 PM
