Help?
Trying to install this morning dont have instructions anyone know the wiring diagram for this
Sony CDX-F7715x HUI
PAC SWI-X I know I use the wires the red white and black
presume
red=power
black= ground
white =?
yes it does have the resistor inline it came from cubby
also once installed how do i program i have my sony remote.
Thanks!
Sony CDX-F7715x HUI
presume
red=power
black= ground
white =?
Thanks!
Ok, all installed but it wont go into ir mode 3, only the program led lights up not both led's when i turn on the key and hold the button....any ideas? see bold no 1 below
6. Programming the Steering Wheel Interface with a version number and 'IR' Mode.
The Steering Wheel Interface has to be programmed for version # 3 and set for 'Standard IR' Mode.
1. Press and hold the Program Button on the Steering Wheel Interface while turning on the vehicle to the accessory position. Both LED's will turn on. when i do this only 1 led lights up so im stuck here...
2. Release the Program Button and both LED's will turn off and then they will turn on for 3 seconds. Wait for 3 seconds and both LED's will turn off.
3. Press the Program Button 3 times. Each time you press and release the Program Button, both LED's will turn on and off. Once you press the Program Button 3 times, wait for 3 seconds. The right LED will flash 3 times indicating it is programmed for version 3. If it flashes the wrong version number, you will have to start over at step 1 above in this section. Turn the key off.
4. Once you have programmed the correct version number, you will not have to do these steps again. If you need to reprogram the SWC and wireless remote functions, you can go directly to the next section.
Originally Posted by Cubs2k,Jun 27 2008, 11:51 AM
I though I gave you the instructions in the Bag
All their installation info in on their web site.....
So I pulled the info off the net after some searching.
