HELP!
Old May 21, 2009 | 05:20 PM
KingzS's Avatar
Default HELP!
so check this out. im driving home from work. i granny drive when im not on the highway btw. and i hear somethin rubbin on my car. i finally get home to find that my driver rear rotor was bein eaten by my brake pad. i take apart the assembly and find that the pad still had a bit more meat on it. and no cracks or burn marks either. baffled i go and buy new pads. i throw on a c-clamp on the caliper but i doesnt budge. took apart the other side. same deal. the caliper cylinder will not budge. so i drained the lines. same deal. now my S is in shambles. oh and i pulled up the e-brake a few times to see if they were seized. and one cylinder fell out. so how do i depress the cylinder so as to fit the new pads???
i PMed Scott but havent gotten a response so i hope anyone else has a solution
thanks
Luis
Old May 21, 2009 | 05:54 PM
Bass's Avatar
you need a special tool because of the e-brake
it screws back in - you can't push them in
Old May 21, 2009 | 05:55 PM
Bass's Avatar
Old May 21, 2009 | 05:57 PM
KingzS's Avatar
WTF IS THAT!?
Bass's Avatar
autozone should have the one above
or something like this
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=40732
Old May 21, 2009 | 05:59 PM
KingzS's Avatar
how can i find that tool? Autozone maybe?
Bass's Avatar
Originally Posted by KingzS,May 21 2009, 09:57 PM
WTF IS THAT!?
props to erick for teaching me this
that's a 6 way rear brake tool - you need to screw the calipers back in so that one is just a multi tool and you line up the correct pins and screw the caliper back in with a socket wrench
KingzS's Avatar
k thanks Bass
Old May 21, 2009 | 06:00 PM
KingzS's Avatar
erick
Old May 21, 2009 | 06:04 PM
Bass's Avatar
and yup autozone has it
it's $12.00 - it's easier if you open the bleeder valve
[URL=http://www.autozone.com/autozone/catalog/accessories/accessoriesShelf.jsp?categoryDisplayName=Tools&fro mType=accessories&fromString=search&parentId=cat30 101&filterByKeyWord=rear+brake+tool+
