New diff installed...vibration
Old May 3, 2007 | 01:08 PM
ymx777's Avatar
Default New diff installed...vibration
Hi all,
I'm getting some vibrations after the dealer installed a new diff. Please see thread below for description.
https://www.s2ki.com/forums/index.php?showtopic=485568
Anyone have any ideas or experiences?
Thanks much.
Old May 3, 2007 | 01:20 PM
ymx777's Avatar
I'm hoping someone has the opportunity to go out to their car and pull on the CV shafts to see if it's loose....? (please )
Old May 3, 2007 | 02:26 PM
dlaio's Avatar
CV loose? Not sure how to test. If I jack the car up (brake off) I cant wiggle the rear tire much. Testing the bearings more than the CV joint. Im my experience if a CV is bad it usually clicks. If you give me a shout what you want me to try will do.
Cheers
~joe
Old May 4, 2007 | 04:52 AM
ymx777's Avatar
Thanks Joe,
Well, I just compared my car with a co-worker's S. I just got under the car without jacking it, and try to move the CV/output shafts. His car had been sitting around for a while, so I was able to move the shaft along its axis (in and out of the diff). I was not able to move it radially (up and down/fwd and backwards). I did the same to my car (except it was warm from driving to his car). I was not able to move the shaft at all.
This is completely different than when the car was in the air at the shop. So my guess is that the car has to be unloaded to get that movement in the shafts. IF you have time or are already doing something in that area, give the output shaft a tug while it's in the air, and see if it moves.
Also, the shop techs gave the suspensions parts and main drive shaft a good tug, and nothing was noticed as loose or abnormal. The only thing was the cv/output shafts.
I really appreciate anything you can do. Thanks!
speakeasy2009
Jul 19, 2013 03:32 AM
PepCsS2k
35
Aug 24, 2011 10:40 PM
S-Turn AP1
Jul 27, 2008 10:17 AM
Talstaff
May 6, 2007 12:34 AM
Talstaff
May 5, 2007 05:47 PM
