oil pan is off
oil pan is off
since i found quite a bit of metal chards in the v tec sol screan i wanted to make sure my crank/bearings were still ok. just wondering what to do to check now that the oil pan is off.
Thanks
dereck
Thanks
dereck
actually everything looks good. Even if it was spun i really wouldn't care cuz the engine builder said he had one he would give me for $100. Sending the block out monday gunna just bore/hone it and replace rods, bearings, pistons (9:1 mahle), balance/blueprinting etc. $2000 for the full build including shipping.
Good news D ..
Here is my thought though . While this is the cheaper way out and lowers the compression to take care of your gasket issue . It still leaves you with delicate cylinder walls that can score easily, and also thinner cylinder walls .
If it was me I would have just simple Darton repair sleeves installed so you now have iron sleeves . You dont need to go crazy with full MID sleeves .But you will sleep better at night knowing a piece of carbon is not going to wipe out the cyl.
Originally Posted by Twiztid,Aug 6 2010, 05:47 AM
Good news D ..
Sounds like our cylinder walls are made of rice paper! That sucks.
Next time you are up I will show you a block . They are only fiber reinforced aluminum .
The 2zz Toyota motor and the H22 honda are the same . But almost everything else is steel lined .
Derick may have to sleeve the block anyway due to possible excessive taper in the cylinder walls . The scratches he has are not bad... ive seen and run engines much worse than his and been fine .
