Once over maintenance
So my S has 60K miles and I am plannin on driving to Billman in New York to get the once over maintenance done and install 4.77s. I live in MA so it's kind of a far drive. You guys know if anyone does that around here? I appriciate it, thanks
Once over:
Custom Valve adjustment, retainer inspection, & spark plug torque check
Air filter
cabin filter
oil change Mobil1 & PCX filter, or ck oil and fliter torque
dif fluid change with Mobil1 75W90
trans fluid change with NEW Honda MTF
clutch fluid change
brake fluid change
spark plug replacement (Honda S2000 spec'd NGK's, not the ones you buy online)
clutch adj
throttle adj
inspect serp belt
air psi
Coolant flush
axle nut tsb
topdown mod
AC mod (02-07)
check brakes
general check-up
Priced individually, only services needed are done.
Billman FTMFW!!
Air filter
cabin filter
clutch fluid change
brake fluid change
clutch adj
throttle adj
inspect serp belt
air psi
Coolant flush
axle nut tsb
topdown mod
AC mod (02-07)
check brakes
general check-up
Billman FTMFW!!
