Refund on tune ?
Old May 23, 2010 | 06:41 AM
ScottyBallistic's Avatar
Does it break up on quick Throttle changes ??
if so , it is not the tuner . It is a bug in the e-manage . Hence why I designed the secondary injection . The greddy does not like running larger injectors . It gets the math wrong on quick throttle changes and make the car freak out .
We have tried to talk to Greddy about it . Giles has even offered to help fix the software . But every time we start talking to the higher up people they just ignore us
Old May 23, 2010 | 09:16 AM
drhess06259's Avatar
No it's bad at idle I have the blinking cel and it sounds like a Subaru lol I know one of my plugs was wet when I checked them and I don't have that issue on the factory ecu there just a little carbon but I am running a 12 a/f on NGK iridums temp 8 and btw thanks Scott closeing up the gap from 32 to 28 made it a lot better at least at idle
Old May 23, 2010 | 09:33 AM
You cant drive it on a blinking CEL , it will destroy the motor for one . That is sever misfire .
Also if he was not reading the factory fuel trim to set the injectors properly and reading when it is in open or closed loop . He will never be able to tune it correctly . So it sounds like he made changes in closed loop and the computer changed things or is trying to change things which messed everything up .
Old May 23, 2010 | 12:49 PM
I didn't drive it on the blinking cel It doesn't blink if I pull the emanage and actually I drove it over 30 miles and it didn't even toss a misfire code
Old May 23, 2010 | 03:32 PM
Like I said above . If he was not doing what I described above .. He has no clue . What it does with and without it means nothing to me other than the tune is not correct
Old May 23, 2010 | 04:38 PM
joes sled 2000's Avatar
Originally Posted by josserman,May 22 2010, 11:37 PM
Jeff Evans is worth the drive!
Theres nothing else to say !
Old May 23, 2010 | 05:29 PM
PuFF's Avatar
didn't anyone read the post i wrote about Swift long time ago....
Old May 23, 2010 | 05:42 PM
zzziippyyy's Avatar
Go read my post in this thread
And how the hell are ya?
Old May 23, 2010 | 05:44 PM
PuFF's Avatar
i'm good zip, working n' gambling
time to bring out the S shortly
Old May 23, 2010 | 05:47 PM
zzziippyyy's Avatar
^ Enjoy the ride Ray
