S2000 tuned with e-Manage Ultimate
So, the other day I had the chance to do a quick tune on a MY03 S with a cold air intake and a newly installed e-Manage Ultimate. For those who don
Giles, can the Ultimate be used to tune off of TPS? That way I can keep the stock ecu with the ITBs? Just wondering.
Giles, how smooth is the final product? Does the engine idle as stock, and start and stop the same? Does the exhaust smoke or smell bad? I'm just wondering about driveability. Also, once done can you just forget about it, or does it need periodic recalibration?
Finally, is the AP 2 really that much stronger than the AP 1? It seems the AP 2 is almos as strong as the modified AP 1. |
BTW, was the baseline with or without the CAI?
Finally, is the AP 2 really that much stronger than the AP 1? It seems the AP 2 is almos as strong as the modified AP 1. It starts and stops exactly like stock. The EU can modify signals at that time but I have it set not to. Actually a lot more can be done in the part throttle area with little advances in timing to make the car much more lively and accelerate quicker. No smoke or smell as it is not running lean AFRs to generate the power in the same way that a V-AFC does. No periodic tuning needed as the stock ECU modifies the injector pulse widths to compensate for temperature change. I think if you look at V-AFC plots you'll find that they don't come near to the power of the AP2, however with the EU you can get the same power as the 2.2l with the 2.0l and still keep 9000 rpm :D |
Originally Posted by gilbertg,Jul 16 2006, 11:53 PM
Baseline was with the CAI - that gives it the bump around 3K.
I still think I might have to look up and try to get a MUGEN ECU. :) Yeah yeah I know you can probably get more HP out of Giles tuning I am sure.
Though at 91,000 miles I wonder if I should be doing ANY OF THESE THINGS. :) |
Originally Posted by Legal Bill,Jul 16 2006, 11:58 PM
How much does all this cost Giles/Scott??
