Originally Posted by Cubs2k,Apr 10 2009, 07:08 AM
His dyno is attached to the rear wheels....so I imagine that these are Wheel HP figures.....
So, the losses in this case are the transmission and drivetrain only. Roller dynos lose a lot of power to inertia, that's why changing wheels, a different gear, or even your flywheel will effect your power output on a roller dyno. With my setup it won't. |
Not all roller dynos are created equal, load types specifically. Software accounts for gears, temps, humidity etc. etc. But lighter wheels and flywheels do make power, they dont make more engine hp they just make it possible to transfer more to the wheels by removing mass. What most people don't know is that there are a lot of factors that go into the calculation, ramp rate can have some effect. Correction factor also, the dyno I have been using for the past few years has a mode called "shootout mode" which is basically a dynojet number. So we can put someones S2k on the dyno and calibrate it as close to 1.0 correction factor as possible then put mine on and put the dyno in shootout mode with a higher number ramp rate and change the correction factor to 1.5 and I can make 60 more whp even if both cars are stock. Its too easy really. Like someone else mentioned, its the delta not the end result.
Giles,
Are you selling the "black" kit yet? Can you give pricing and more details possibly? Thanks! Erik |
Originally Posted by Enlightened,Apr 16 2009, 04:52 AM
Giles,
Originally Posted by gilbertg,Apr 16 2009, 01:57 PM
Really close. I have one test to perform today and then ...
Originally Posted by gilbertg,Apr 16 2009, 04:57 AM
Really close. I have one test to perform today and then the website will be updated this weekend with all the information. I'll post a link as soon as it's done...
Excellent! So many questions, but I have only one for now. I plan on running a 70mm Berk high flow cat (with their header) instead of test pipe, and was wondering if I can still use the "test pipe" setting with this new kit as to lower the VTEC. I spoke with Scott and will also be sending you my LC-1 controller for modification, as I recently bought it new with the gauge. Let me know! Erik |
:D |
:thumbup:
For those folks who have questions related to the Chrome and Black kits please post them in this linked thread on the Ballistic board:
http://ballisticmotorsports.org/forums/YaB...?num=1240586739 |
