Thunderstuds!
Hey Erick, is this what you used to install your lift?
http://www.confast.com/products/thunderstud-anchor.aspx
It's not that the anchors won't hold, it's a question of whether the slab will support the weight of the lifted car. There's specs regarding the thickness and quality (psi) of the concrete.
If your slab isn't up to spec, you can probably cut out squares, dig down to the prescribed depth, and pour footers for the lift. Kind of like the footers under the posts in your basement. Those posts don't rest on the 4" slab, but rather on piers of concrete several feet down.
Since a failure of the lift while you're under it would be unpleasant, I would pay attention to the manufacturers recommendations.
Originally Posted by Legal Bill,Dec 19 2009, 08:10 AM
Thanks for that info. I know the concrete is very thick in some areas, but I'm not sure how thick it is in the bay where I would put the lift.
